Anyone usind Mallory Window switch?
Old Feb 16, 2005 | 07:29 AM
96blkform's Avatar
I bought my TNT wetkit a couple weeks back and it was for an LS1. I am getting the LT1 TB plate. Kit included a number of accessories, such as NOS bottle warmer with wiring, purge kit, autometer gauges and then also the window switch. I however got no wiring diagrams for all the accessories. I was hoping to find out the wiring for the window switch, it is connected to the relay for the N2O already, but I am trying to find out which wire is the tach wire? 2 Wires have been cut and are not used and then there is the green left, is the green the tach wire? Also I am getting an msd 6AL box, would the tach wire off the window switch just connect to the tach output off the ignition box?
Then, I have the nos bottle warmer and then also the wire harness with the relay, hoping to find out the wiring diagram for it, want to use the relay and do not want to hard wire it.
Lastly, does anyone have a diagram for the purge wiring and setup. It would awesome if someone might have a complete diagram of their setup including the purge and gauge connections. The gauges are going to be mounted inside the car in the center vents, they are 2 5/8 gauges. My e-mail is craigs96formula@yahoo.com I also did not get a fuel pressure safety switch, I looked at summit, but they have a number of different ones, which one should I order.
Craig.
Old Feb 19, 2005 | 02:28 PM
OBE1 95Z28's Avatar
Re: Anyone usind Mallory Window switch?
Green wire connects to the ignition system tach output. Black wire is ground, red wire is 12 volts. The orange wires will "connect" the device when the low rpm valve is reached, and shut it off when the high rpm valve is reached.
Old Feb 20, 2005 | 08:28 PM
96blkform's Avatar
Thanks for the info OBE1 95Z28, just what I have been searching for
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
