adding a fuel pressure safety switch to this schematic....
Old Feb 1, 2007 | 08:25 PM
69z-28's Avatar
can someone use this diagram here...
and throw in a Fuel pressure safety switch. will i need another relay?
Old Feb 1, 2007 | 08:44 PM
Daniel6718's Avatar
ground side of the noids...no relay needed
Old Feb 1, 2007 | 08:45 PM
69z-28's Avatar
ground side of the noids then ground the other side of the switch to the frame?
Old Feb 1, 2007 | 10:49 PM
97formulakid's Avatar
no relay. i have mine on the ground side of the mallory. I have seen them grounded from the relay and the solenoids also.
Old Feb 2, 2007 | 12:24 AM
Daniel6718's Avatar
yes, if you have a mallory run the noids into it, then the other side to the mallory...or any other window switch...if not, if its just on a wot switch then run it between the ground, it can basically go alot of places, just needs to be able to break a connection that will cause the sirsuit to fail
Old Feb 2, 2007 | 07:20 AM
magicvega's Avatar
Being new to nitrous i think the schematic os pretty helpful. it would be great to have a full blown one for having a fpss and all in the loop. Good job so far im interested to see where this goes hehe
Old Feb 2, 2007 | 09:04 AM
Nitro Dave's Avatar
Put the fuel pressure safety switch em between the orange wire from the Mallory unit and pin 85 on the relay.
Dave
Old Feb 2, 2007 | 07:24 PM
69z-28's Avatar
dave, just hook side of the switch to mallory and other side to relay and thats all?thanks for the help guys
Old Feb 3, 2007 | 02:26 AM
Ray@NitroDaves's Avatar
Yep.....
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
Jul 4, 2005 05:00 PM
