? about timing retard
Old Mar 30, 2003 | 07:21 PM
Z28ROC's Avatar
I have a 6al and an MSD start/retard box.
Does anyone know if the white wire is used in an LT1 application.
Also should I use the N20 solenoid to activate it, or use the rpm window switch? It doesn't seem like the window switch would work. Being that the retard box is activated when there is a break in ground.
mikey4play
Mar 15, 2015 11:45 AM
nophix
Nov 30, 2014 10:26 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
ScottZ
Mar 3, 2004 01:34 PM
