224/236 cam 150 max?
Old 04-29-2004, 10:18 PM
limige's Avatar
combination motorsports labels the 224/236 on a 114 a nitrous/supercharger cam. they say it's good to a 150 shot.
what happens when you spray more? do you need more lift or duration for a larger shot?
i'm wondering cuz i was thinking about spraying more than 200 to it, probably two stage wet.
thanks,
mike
btw- no boost, can't afford the sc. yet.
limige is offline
Old 04-30-2004, 05:47 AM
Moderator
rskrause's Avatar
As the amount of N2O injected gets larger, the cam will act "smaller", just as the same cam installed in a bigger motor does. It won't hurt anything, however. Just won't produce quite as large a hp gain and will hit peak power at a relatively lower rpm. But from your sig, I get the impression that you have a stock shortblock. If that's the case, the cam won't be a problem with a >200hp shot. The problem is more likely to be picking up all those shiny metal pieces.
Rich Krause
rskrause is offline
Old 04-30-2004, 10:12 AM
andy katzelis's Avatar
Nice call!
andy katzelis is offline
Old 04-30-2004, 10:19 AM
limige's Avatar
thanks for the reply. but i haven't updated my sig in over a year.
i have a set of speed pro forged pistons for a 355, right now i'm down to a bare block ready for boring.
get this, i found out someones been in this thing, all the rods are stamped, the bearings are all fresh and there is no ridge on the top of the cylinders! at 90,000!
my guess is its a fresh block, go figure, oh well, it's apart now.
i'm still trying to decide on rods and crank. i'm doing this on a serious budget. if you had to do one which would you do, rods or crank?
heads are going through some meticulas porting and polishing.
i have edelbrock shorties coated, custom ypipe, long tube style.
i'm probably going with a spec stage 4 clutch. and rebuilding the trans.
i have a set of solid roller lifters and the 224/236 cam.
so heres the debate.
i'm getting a vilper nx kit which is a dual nozzle 100-300 shot.
should i sell my 224/236 cam and buy a different grind and go solid roller.
or sell the solid roller lifters and go with the 224/236 cam.
this car willl still be driven on dry days in the summer. pretty much a daily if it ain't raining, but at the track i plan to put the juice to her!
thanks
mike
limige is offline
Old 04-30-2004, 12:16 PM
Moderator
rskrause's Avatar
I'd keep the cam. As far as crank v. rods, get a nice set of rods and some heavy duty wrist pins. The crank will be fine.
Rich Krause
rskrause is offline
Old 04-30-2004, 03:14 PM
limige's Avatar
thanks rich
limige is offline
10-31-2016 11:09 AM
onefastgta
03-19-2015 10:09 AM
Noer
02-28-2015 11:29 AM
nikolt1
02-27-2015 09:10 PM
alex5366
02-17-2015 09:07 AM
Quick Reply: 224/236 cam 150 max?
