2 questions
Old Apr 22, 2004 | 09:26 PM
the1turkey's Avatar
2 questions
i went to talk to my speed shop guy today about my install and came up with 2 questions
i plan on locating the bottle on the hump between the 2 rear seats where should i run the blow down tube
and he said on my a4 that a window swith wasn't nessary because it would never drop down below the required rpm's and that spraying through shifts was better then cutting the nitrous and then resprying after a shift because thats alot of shock on the tranny each time the nitrous kicks in after a shift makes since to me but what do u guys think
Old Apr 22, 2004 | 10:19 PM
RacinLT1's Avatar
run the blowdown through the floor,or use braided line with a bulkhead fitting in the floor to vent it.
as far as spraying through shifts,you better have faith in your trans builder because a stocker wont last long with that kind of abuse. the stock trans doesnt shift fast enough and builds up a LOT of heat in the clutches. dont ask how i know this
Old Apr 22, 2004 | 10:21 PM
LPEdave's Avatar
...and you can certainly bog an automatic transmission, the same way you can a manual. I always recommend the window switch.
Dave
Old Apr 22, 2004 | 11:42 PM
the1turkey's Avatar
thanks i might just have to add the the window swith if your gonna do somthing mise well do it right the first time
Old Apr 23, 2004 | 07:18 AM
oil pan 4's Avatar
Don't be out $1000's trying to save a few $ on a windo switch.
How much were you going to spary?
Old Apr 24, 2004 | 03:15 PM
the1turkey's Avatar
100 shot
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
