2 question please help.
OK first I have autolite 103's in now and they idle like crap what ngk's would be the same heat range?
2nd what kind of relay can i use to wire up my bottle heater it is a nx heater i have the switch the heater and the thermostat thing that hook to the line? Thanx in advance John
Just use a 40 amp Bosch relay and you'll be fine. You can get some NGK R5671-8. These are race plugs but they are a pretty cold plug. If you have a stock motor then use the NGK TR6's.Gap them at .035.
Matt
Matt
Deadbolt24
Jan 19, 2015 01:29 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
