175-200 shot on stock bottom end?
Old Nov 27, 2003 | 07:18 PM
  #16
a walker's Avatar
Originally posted by Rival
I would spray a ls1 to a 200 shot way before an lt1.
Actually, from the research I have done, the LT1 has a stronger bottom end than the LS1. Sure, the lS1 has a 6 bolt main, but it is in an aluminum block vs. the LT1's iron block.
I have had a 175 shot on my car for four years now with not one bad side effect. I now have 166,000 miles on the stock engine, and it still goes low 13's n/a. It's all about how it's used and installed.
Old Nov 28, 2003 | 12:31 AM
  #17
Drew778/94Z's Avatar
Originally posted by RacinLT1
i ran a 35 fuel jet and my car was STILL fat on the 175 shot. the 38 bogged it down.
What was your bottle pressure and what race gas do you use?
Old Nov 28, 2003 | 10:21 AM
  #18
RacinLT1's Avatar
i always strived to run 1000-1050 bottle pressure. everyonce in a while it was between 1050-1100 but i usually purged it down to a steady 1050.
as far as fuel,the car was run on VP C10 or sunuco 104 unleaded. it might of had at most 3-4 gallons of 93 but always got at least 5 gallons of 100-104 unleaded.
I kinda like the vp fuel better,seems slightly more consistent in the way my car ran. but sunoco is sold at the track and i use it in a pinch.
Old Nov 28, 2003 | 01:55 PM
  #19
Cool, when I sprayed the 175 shot, I used NX 72N 41or42F, bottle pressure was 850-900, I used 3 gallons of C-14 to a 1/4 tank of 92 pump gas.
I wonder what the car would run with 1050 bottle pressure
DirtyDaveW
Dec 1, 2016 05:37 PM
Killer94z
Jan 13, 2015 12:06 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
97 RedSS
Jun 10, 2003 07:58 PM
