175, 200, and 250 jets
Old Sep 13, 2004 | 02:51 AM
lt1camaroman93's Avatar
I need to know the jet sizes for 175, 200, 250 for either a single nx shark nozzle or a dual shark nozzle set up. I need the jet sizes for 42# of fuel presure and also the jets for 55# of fuel pressure. Thank you.
Old Sep 13, 2004 | 05:52 AM
rskrause's Avatar
Moderator
Re: 175, 200, and 250 jets
If you do a search in this forum you will see a lot of jet size discussions.
Rich
Old Sep 13, 2004 | 09:21 AM
I did do a search and i did not find what i was looking for. I found one jet calculator but it seemed to be way off. If someone knows of a good calculator than that would be great.
Old Sep 13, 2004 | 09:27 AM
Nostang 96z's Avatar
This is a very good calculator. Dead on accurate for me.
http://cosmik.org/calculators.htm
Matt
Old Sep 13, 2004 | 03:37 PM
Black95Form's Avatar
Link no worky
Old Sep 13, 2004 | 09:57 PM
thats the one i used to use and it was always right on.. but the link doesn't work anymore.
Old Sep 13, 2004 | 10:58 PM
DrewHMS97SS's Avatar
off topic: why the hood pins?
Old Sep 14, 2004 | 08:07 AM
I have shaved as much weight as i can off of the car. The is nothing behind the nose of the car now, no impact absorber, no hood latch, just the nose of the car. I am also planning on getting a fiberglass hood over this winter.
Old Sep 14, 2004 | 09:14 AM
mtxpert's Avatar
http://www.azsupersport.com/nitrousjetcalc.asp should work fine for you.
Mike
Old Sep 14, 2004 | 11:31 AM
you know of anything that will calculate for a dual nozzle?
Old Sep 19, 2004 | 11:05 PM
n20ta2's Avatar
this kinda has me puzzled as every manufacturer recommends a diff jet size for there selonoids using the same nozzle.It was explained to me by nos and NW that the diff brands cellonoids have different flow ratings and there for require a diff jet. I use NOS pro shot celonoids and 2 NOS fogger nozzles and got the reccommended jetting from NOS tech line,I tried diff companies to get jetting and they couldnt help me.
Old Sep 20, 2004 | 11:46 AM
that sounds accurate. most companies will jet fuel high and n2o moderate. the only real way to get the perfect jetting it to run it one the car and tune it for your application.
Old Feb 3, 2005 | 02:13 AM
BlueCamaroZ28's Avatar
Mike
Does it matter with this calculator if the engine is 8, 6,or 4 cylinders?.
I've seen different Jets sizes for the same HP rating on different engine sizes.
Old Feb 3, 2005 | 06:16 AM
rskrause's Avatar
Moderator
1. size (displacement) or number of cylinders is not relevant
2. jet sizes are additive (eg. two 75hp nitrous and fuel jets = one 150 set of jets)
3. within broad limits the size of the solenoid has little to do with the correct jetting. *** you approach the flow limit of the solenoid it could become an issue though.
Rich
G-BODYT56
Jan 14, 2022 11:14 PM
GREEN3112
Feb 10, 2019 09:19 PM
95chwagon
Oct 16, 2015 12:24 PM
alliance12364
Sep 23, 2015 06:09 AM
95blkss
Sep 22, 2015 03:18 PM
