150 Shot!!!
Old Jul 8, 2005 | 01:41 PM
vonmoldy's Avatar
150 Shot!!!
I want to run a 150 shot on my stock motor I am not sure if I should get a wet or Dry kit. Is this amount of nitrous going to make my engine all stressed out or will it last a long time on it? What type of setup would you suggest such as what plugs? a particular system over another?
Old Jul 8, 2005 | 04:04 PM
HarrisSpeedWorks's Avatar
Re: 150 Shot!!!
At that power level I would look at a wet setup. You could do a dry, but you will have to buy large enough injectors to support that size shot. If you use the proper safety equiptment (FPSS, window switch, I would upgrade the fuel pump) and get a good tune (pull timing, keep it a bit rich) a shot that big can last. The NGK TR-6's are good nitrous plugs. Take a look at our wet kits. We offer a lifetime warranty on them, if you're not happy with it we offer a full refund. Let us know if you have any other questions.
Matt
Old Jul 8, 2005 | 04:53 PM
Nitro Dave's Avatar
Re: 150 Shot!!!
I agree,
You will be happier with the wet system.I suggest a Nitrous Express stage one system.They are hands done the best system on the market.
Dave
Old Jul 9, 2005 | 10:49 AM
97SS0594's Avatar
Re: 150 Shot!!!
as a precautionary measure id upgrade your fuel pump along with your injectors. 150 hp comming in suddenly is like taking a sledge hammer to your rods, id deffinately get a RPM window switch. how many miles on your car? if your over 100k dont even bother with a 150 shot just come in with a little something like a 75 shot, and the more daring you get keep moving up. i have a zex dry kit 125 shot and i love it! i also have a NOS wet kit (super powershot) on my plymouth laser RS turbo, that kit works well too although ive only touched it off very little (never had the need to)
Old Jul 9, 2005 | 10:50 AM
Derrick Redd's Avatar
Re: 150 Shot!!!
Another vote for the NX wet kit.
Old Jul 9, 2005 | 01:44 PM
FatalZ28's Avatar
Re: 150 Shot!!!
What about TNT? I have heard good things about their plate systems..
TNT LT1/LT4 Nitrous Kit
Old Jul 11, 2005 | 11:22 AM
Nitro Dave's Avatar
Re: 150 Shot!!!
TNT has some good products.However I do not like the idea of having two nozzles behind the throttle body spraying to the back of the intake.The front runners are way to close.The nitrous does not have enough tome to mix in the air streem and hit each runner properly.
Dave
Old Jul 14, 2005 | 12:57 PM
Daniel6718's Avatar
Re: 150 Shot!!!
dont really wanna jack this thread but it also might pertain to him...for a 125 shot or bigger wouldnet u want to reatard timing??? or is the knock you get from the knock sencor enough reatrd if its only 3or 4 mayb 5 degrees???
or doi u not worry bout that till u get around 175 shot???
Old Jul 15, 2005 | 05:10 PM
Re: 150 Shot!!!
Sure, it wouldn't hurt to pull some timing, but it isn’t absolute necessary at that size shot.
PS - You never want the knock sensor to pull timing for you. It's a safety device to prevent detonation. If it's pulling timing for you then you're detonating.
Matt
Old Jul 15, 2005 | 07:51 PM
Daniel6718's Avatar
Re: 150 Shot!!!
lol ok...i was jus thinkin since almost every1 has a few degrees anyways if that waS enough to make it safe for a 150 shot...but mostly i was wondering if 150 was ""Safe"" without pulling timing, or is everybody else pulling timing for that kinda shot? guess its not a must unless ur jus worried alot about it motor
Daniel
Old Jul 18, 2005 | 09:01 AM
jsetzer's Avatar
Re: 150 Shot!!!
My experience, your results may vary.
Stock motor, stock fuel, 120k miles.
150 shot was only used 3x on dyno day, and a few times on the highway coming home from the dyno. Rest of the time was 100-125 jets. Never pulled timing, always ran at least 93 gas. Seemed to hold up just fine.
Mine was a cold fussion wet kit.
Here is what mine did. Clicky
Old Jul 18, 2005 | 06:12 PM
chevy94c's Avatar
Re: 150 Shot!!!
Go with either NX or dynotune kit.
Old Jul 26, 2005 | 01:48 PM
MetallicTrans96's Avatar
Re: 150 Shot!!!
I have a Nitrous Works plate wet system. I really like it. Im going tomorrow to get my car tuned and they are going to pull some timing to tune in my nitous. I am going to ask about running a 150 shot on stock internals.Im running 125 now and have run 2 15lb bottles through and everything is fine.69,000 miles
Old Jul 26, 2005 | 01:59 PM
94irocz's Avatar
Re: 150 Shot!!!
I have a 150 shot on my stock bottom end 149k 94 z28. Its an nx wet kit with a tps switch and a window switch and fpss. Its made a best of 489rwhp with it rich dropping off the charts. I've ran two bottles of 150 through it and 3-4 bottles of 100 shot through it. If its set up right it should last. I also have some timing pulled out.
Old Jul 29, 2005 | 02:31 PM
baddboy1705's Avatar
Thumbs up Re: 150 Shot!!!
no one here for a ZEX kit? heard there pretty good too...
LT14LIFE
Nov 15, 2015 06:22 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
Sep 17, 2015 11:53 AM
NewsBot
Sep 15, 2015 11:53 AM
