150 Shot!!!
150 Shot!!!
I want to run a 150 shot on my stock motor I am not sure if I should get a wet or Dry kit. Is this amount of nitrous going to make my engine all stressed out or will it last a long time on it? What type of setup would you suggest such as what plugs? a particular system over another?
Re: 150 Shot!!!
At that power level I would look at a wet setup. You could do a dry, but you will have to buy large enough injectors to support that size shot. If you use the proper safety equiptment (FPSS, window switch, I would upgrade the fuel pump) and get a good tune (pull timing, keep it a bit rich) a shot that big can last. The NGK TR-6's are good nitrous plugs. Take a look at our wet kits. We offer a lifetime warranty on them, if you're not happy with it we offer a full refund. Let us know if you have any other questions.
Matt
Matt
Re: 150 Shot!!!
as a precautionary measure id upgrade your fuel pump along with your injectors. 150 hp comming in suddenly is like taking a sledge hammer to your rods, id deffinately get a RPM window switch. how many miles on your car? if your over 100k dont even bother with a 150 shot just come in with a little something like a 75 shot, and the more daring you get keep moving up. i have a zex dry kit 125 shot and i love it! i also have a NOS wet kit (super powershot) on my plymouth laser RS turbo, that kit works well too although ive only touched it off very little (never had the need to)
Re: 150 Shot!!!
Re: 150 Shot!!!
Originally Posted by FatalZ28
Dave
Re: 150 Shot!!!
dont really wanna jack this thread but it also might pertain to him...for a 125 shot or bigger wouldnet u want to reatard timing??? or is the knock you get from the knock sencor enough reatrd if its only 3or 4 mayb 5 degrees???
or doi u not worry bout that till u get around 175 shot???
Re: 150 Shot!!!
Sure, it wouldn't hurt to pull some timing, but it isn’t absolute necessary at that size shot.
PS - You never want the knock sensor to pull timing for you. It's a safety device to prevent detonation. If it's pulling timing for you then you're detonating.
Matt
Matt
Re: 150 Shot!!!
lol ok...i was jus thinkin since almost every1 has a few degrees anyways if that waS enough to make it safe for a 150 shot...but mostly i was wondering if 150 was ""Safe"" without pulling timing, or is everybody else pulling timing for that kinda shot? guess its not a must unless ur jus worried alot about it motor
Daniel
Daniel
Re: 150 Shot!!!
My experience, your results may vary.
Stock motor, stock fuel, 120k miles.
150 shot was only used 3x on dyno day, and a few times on the highway coming home from the dyno. Rest of the time was 100-125 jets. Never pulled timing, always ran at least 93 gas. Seemed to hold up just fine.
Mine was a cold fussion wet kit.
Here is what mine did. Clicky
Re: 150 Shot!!!
I have a Nitrous Works plate wet system. I really like it. Im going tomorrow to get my car tuned and they are going to pull some timing to tune in my nitous. I am going to ask about running a 150 shot on stock internals.Im running 125 now and have run 2 15lb bottles through and everything is fine.69,000 miles
Re: 150 Shot!!!
I have a 150 shot on my stock bottom end 149k 94 z28. Its an nx wet kit with a tps switch and a window switch and fpss. Its made a best of 489rwhp with it rich dropping off the charts. I've ran two bottles of 150 through it and 3-4 bottles of 100 shot through it. If its set up right it should last. I also have some timing pulled out.
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
Sep 17, 2015 11:53 AM
NewsBot
Sep 15, 2015 11:53 AM
