10lb Bottle, 35 Shot.. How long will it last?
Old Jul 31, 2009 | 02:42 AM
V8 Slayer's Avatar
Wiring with a TPS WOT switch. How many WOT passes would a 35 shot, 10 pound bottle last.. about..?
And... How much does Nitrous usually run? Per lb?
Old Jul 31, 2009 | 11:12 AM
Ray@NitroDaves's Avatar
the rule of thumb is 1lb in 10 sec for every 100hp
50hp will use 1/2 pound in 10 seconds
200hp will use 2 pounds in 10 seconds
Nitrous refill rates will vary but $4-5 per pound seems about average
Old Jul 31, 2009 | 01:07 PM
Z-RATED94's Avatar
If you stick with a 35 shot, you can run the bottle down farther. But I still wouldn't go past leaving at least 2-3 lbs. in the bottle. I run a 140 shot and only expect 2 runs before the preformance starts to fall off. I sometimes make a 3rd run, but know the et will be slightly worse.
Edit: bought my system from some guy named Ray at Nitrous Outlet. LOL I'm very happy with the results.
Old Aug 1, 2009 | 08:44 PM
V8 Slayer's Avatar
Does such a small shot such as a 35 require any timing or plug/gap adjustments?
Old Aug 2, 2009 | 12:41 PM
Z-RATED94's Avatar
Maybe not, but don't go by me. You never did mention what car and motor this is for.
Bobczar
Oct 23, 2015 11:22 AM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
grabbem88
Feb 23, 2015 09:41 PM
taner
Aug 23, 2002 05:25 PM
