10lb Bottle, 35 Shot.. How long will it last?
Wiring with a TPS WOT switch. How many WOT passes would a 35 shot, 10 pound bottle last.. about..?
And... How much does Nitrous usually run? Per lb?
the rule of thumb is 1lb in 10 sec for every 100hp
50hp will use 1/2 pound in 10 seconds
200hp will use 2 pounds in 10 seconds
Nitrous refill rates will vary but $4-5 per pound seems about average
If you stick with a 35 shot, you can run the bottle down farther. But I still wouldn't go past leaving at least 2-3 lbs. in the bottle. I run a 140 shot and only expect 2 runs before the preformance starts to fall off. I sometimes make a 3rd run, but know the et will be slightly worse.
Edit: bought my system from some guy named Ray at Nitrous Outlet. LOL I'm very happy with the results.
FMFRacing88
May 25, 2015 08:08 PM
taner
Aug 23, 2002 05:25 PM
