~250 shot, is this 383 bottom end okay???
Old Dec 13, 2004 | 11:09 AM
texasTA's Avatar
I plan on spraying my stroker with a NX 200-300 shot. I am about to build up a 383 LT4 motor. I already have the heads ported, I am going with a custom Cam Motions cam, and I need to piece my bottom end components together.
I was thinking of going with a Callies Dragonslayer 3.75 forged crank, Lunati Pro-Mod Rods, and forged JE/SRP forged pistons, along with Clevite bearings and Hellfire rings.
I was told that this might be a little overkill for my application. I was told to go with the Eagle forged 4340 setup of rods/crank and the JE pistons.
My plans are for a street cruiser car first and foremost, with the occasional NX shot at the track. Occasional as in maybe 2 trips a month with about 6 sprays per trip.
Also, what length rods do you go with a stroker nitrous motor? 6 inch or 5.85 inch.
Also, what type of pistons do I want to go with? I don't understand the -16cc stuff. I want a high compression 383.
Old Dec 13, 2004 | 07:37 PM
tireburnin's Avatar
Re: ~250 shot, is this 383 bottom end okay???
What you posted should me more than fine for a 250 shot. Just make sure you go with 4 bolt splayed mains.
As for pistons, look at nitrous specific pistons. They have lower ringlands to keep away from the heat/pressure. The dish helps establish the compression ratio. A larger dish makes for a lower compression in most cases. Look for a nitrous piston in the range of 11:1 compression for a pump gas engine. Depending on fuel in your area (93) you could go 12:1 with a good tune. But high compression engines 13:1 and such usually require high octane gas which gets to be money for street driving.
Also do lots of searching here or on LS1techs nitrous section before you go spraying a large shot. You need to consider plugs and fuel and more.
Old Dec 13, 2004 | 07:42 PM
tireburnin's Avatar
From what I understand a 5.85 rod is probably better, but many manufactures make nitrous pistons for a 6.0 rod. If you don't mind a 2 month wait you could go with a custom piston and make it do what ever you want. My setup is a 6.0 rod with a custom nitrous piston from Diamond for 11:1 compression.
Old Dec 13, 2004 | 07:53 PM
MEAN_SBC's Avatar
I'm squeezin 350 shot on Scat 4340 crank, and scat 4340 Ibeam 6 inchers.... Haven't had a problem yet...
Old Dec 18, 2004 | 07:46 PM
MLBurns's Avatar
I have splayed mains, Cola crank, Lunati Pro Mods (5.85) and J/E pistons. Spray it with 300 shot countless times. Just have a good fuel system and tune and you should be fine. It definitely will find the weak links in the drivetrain.
Victor Lamb
Aug 26, 2017 02:52 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
grabbem88
Feb 23, 2015 09:41 PM
Killer94z
Jan 13, 2015 12:06 PM
