Tuesday Milan check-in procedure
Just enter around the pit entrance side, there won't be anyone at the booth, find a spot to park in the pits and look for a guy named Matt. He'll set you up.
Spectators will need to sign in as well. Also some consession stands will be open.
1967 Camaro SS - 468 BBC modified
1967 Camaro RS - 327 stock
1969 Camaro Z/28 - DZ302 stock
2000 Ducati 996
Member of the Eastern Michigan Camaro Club
2000 Ducati 996
Sweet I'll see ya guys there...
94 Quasar Blue z28 A4 3.73's, pcmforless programming, shift kit, optima 16" rims, K&N FIPK, cat removed, airfoil, msd superconductor wires, accel coil, ac delco platinum plugs (.050" gap), 1le elbow, 160 deg. thermo, 1st gear select, nitto 555r's, fan switch
Best Rxn: .503 Best ET: 13.680 @ 101.77 on bad 2.064 60ft.
