Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
towing question?
Old Oct 25, 2003 | 02:42 AM
kandied91z's Avatar
towing question?
those of you that tow.....do you leave the car in park or neutral???
dumb question but i've never really gotten a straight answer.
Old Oct 25, 2003 | 06:05 AM
Grover's Avatar
It depends.
If the car is on a trailer you could leave it in park, but if it is on a tow dolly with the rear wheels on the ground you would want it in neutral. I have also heard that you should remove the driveshaft, but I'm not sure why since the tranny is full of fluid it would be getting lubricated.
Old Oct 25, 2003 | 06:20 PM
Chris Ja's Avatar
Eternal Member
You pull the driveshaft on a auto trans because the motor is not running some the pumps in the trans are not working. With a trailer you can leave the car in parks as long as it is tied down and can't move. If there is to much play in th tie downs it will brake the park pin. Hope this helps Jeff.
Old Oct 26, 2003 | 12:25 PM
kandied91z's Avatar
thanks guys!!
Old Oct 26, 2003 | 11:08 PM
AL SS590 M6's Avatar
Moderator
On the trailer I put mine in park but always lock the e-brake tight so that there is no strain on the park pin.
Old Oct 27, 2003 | 02:21 AM
Jay-Roll's Avatar
If the car is on a dolly couldn't you just put the rear tires on the dolly? That way the driveshaft and everything could stay in tact. All you'd have to do is make sure the steering wheel is locked so the tires don't turn. That's the way I'd always figure it anyway.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
