Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
thanks to the Deblers for putting on M13 :)
Old Oct 9, 2008 | 06:30 PM
  #31
WHPLASH's Avatar
Originally Posted by 1BADAIR
1.46
Dayum. And you spun?
Old Oct 9, 2008 | 06:41 PM
  #32
TSO RACER's Avatar
Originally Posted by AutoRoc
Building boost in a turbo car like that can be a delicate process.. He's basically getting the driver REALLY close to the first beam so he can build a little boost on the footbrake, then maybe he'll lite the first bulb and build as much boost as his footbrakes will hold(ie: he's basically standing on the brake pedal..haha)...when the car pushes into the second stage beam, he'll engage the transbrake and put the throttle to the floor for max boost and minimal time against the transbrake....less time sitting there at full power is less wear and tear on the driveline, etc..
Basically...I could be way off base though..
We race heads up on a pro-tree. If you are not on the pipe when you light the second bulb, you are done. When you are racing against other turbo cars that don't have their program together, by pre-staging 1st you can put a lot of pressure on him and cut down his chances to be ready and that will get you a easy win. I don't care when I go in I am ready regardless.
Old Oct 9, 2008 | 06:46 PM
  #33
TSO RACER's Avatar
I held back enough boost with my footbrake to run a 8.55 and get into the Q-16. A well designed brake system will hold back all the power you need.
Old Oct 9, 2008 | 07:26 PM
  #34
1BADAIR's Avatar
yeah, its slow
Old Oct 10, 2008 | 12:28 AM
  #35
AutoRoc's Avatar
Other than Chris White's red GN, yours is the fastest I've ever seen in person...Very nice up close also.
Old Oct 10, 2008 | 05:43 AM
  #36
TSO RACER's Avatar
Thanks for the compliment. Chris's car has run some sick times. We are also running the times we are on stock style heads not Stage 2 heads. We are planning on going with a turbo LSX next year and running drag radial at Milan and where ever else we have time to go. Not sure if you guys came around our camp or not but there was a engine exchange with our engine Builder Dan Strezo who was also there. He was part of Precision Turbo and Engine. Dan was the Engine part of that company. He is building (2) LS engines over the winter and one of them a LS2 based street engine, and the other a LSX that will be a little more radical. Both will be turbo power.
Old Oct 10, 2008 | 09:07 PM
  #37
JasonD's Avatar
Admin Emeritus
Glad everyone had a good time. Thanks for being a part of it!
I'll update the event site sooner or later with the usual wrap-up.
Old Oct 15, 2008 | 06:18 PM
  #38
SROACH's Avatar
Any pics?
Heathen1
Jan 2, 2016 04:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
JasonD
Sep 24, 2002 11:40 PM
JasonD
Jul 15, 2002 02:17 PM
