Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
recommendation for someone to plumb a fogger kit?
Old Feb 9, 2004 | 07:59 AM
Timberwolf's Avatar
I can install the nozzles and everything, I just want the hard lines bent and installed...
Old Feb 9, 2004 | 04:33 PM
Black Sunshine/ 00SS's Avatar
If you can install the nozzles, then you can install the lines. I know the tubes should be the same length. I think I have a link from NOS on instructions. You might want to go to their site and do a search & see what you come up with.
You can bend them with a simple hand held bender. Practice up on some cheap brake lines & once you have that mastered, tackle it.
How much ya gonna spray it
Old Feb 9, 2004 | 04:52 PM
Timberwolf's Avatar
ok cool. I just wasn't sure how hard the line was. if it's like brake line then it shouldn't be a problem.
Well, I'm setting it up to handle a 300+ shot
Old Feb 9, 2004 | 04:58 PM
Derty might be able to give you some tips, I think he bent his own. You might need a flare kit & a hand held bender. Good luck.
Old Feb 9, 2004 | 05:27 PM
ltlhomer's Avatar
Pro-tech performance right outside Toronto. John is the man there and his work is second to none. But if Derty can do it, then that's prolly the way to go since his looks good and obviously works plus you wouldn't have to ship your intake or drive 4 hours.
Old Feb 9, 2004 | 06:36 PM
OneBad98Z's Avatar
Its not a big deal at all just take your time, and like previously said it's nothing more than brake line.
Btw. Mike, would friday be ok to meet up for the sale?
Old Feb 9, 2004 | 06:44 PM
Timberwolf's Avatar
Friday should work no problem. I have a guy in Saginaw that wants the intake setup off my 2nd gen, so maybe I could coordinate both the same day and shorten your drive a bit. How about meeting in Flint?
Victor Lamb
Aug 26, 2017 02:52 PM
mightymouse383
Jul 20, 2016 07:34 AM
R@mpage
Apr 20, 2015 10:02 AM
carl.froehlich
Mar 13, 2015 12:38 AM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
