Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
'nother dumb question
Old Feb 12, 2003 | 10:54 AM
MichiganSkip's Avatar
Just tied up the loose ends on the converter install. I had to put the tranny in neutral to get the driveshaft lined up at the rear end. Now the shifter won't go into Park I have the tranny linkage in Park now with the shifter cable off and the shifter still won't go into Park. Any clues?
Skip
Old Feb 12, 2003 | 01:02 PM
jzajac1's Avatar
Shift Cable Replacement
Removal Procedure
Disconnect the negative battery cable. Refer to
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Raise the vehicle. Suitably support the vehicle. Refer to General Vehicle Lifting and Jacking in General Information.
Unsnap the range selector lever cable from the range selector lever on the transmission.
Remove the retainer and the range selector lever cable from the cable bracket.
Lower the vehicle.
Remove the front floor console trim plate. Refer to Instrument Panel, Gauges, and Console.
Remove the range selector lever cable from the automatic transmission control.
Remove the retainer and the cable grommet from the base of the automatic transmission control.
Pull the cable through the hole in the front compartment floor pan.
Installation Procedure
Install the cable grommet to the base of the automatic transmission control.
Feed the cable through the hole in the front compartment floor pan.
Install the range selector lever cable to the automatic transmission control.
Install the front floor console trim plate. Refer to Instrument Panel, Gauges, and Console.
Important
The automatic transmission control must remain in the (N) Neutral position until the cable installation is complete.
Place the automatic transmission control in (N) Neutral.
Install the range selector lever cable to the cable bracket. Ensure that the adjustment button is unlocked.
Place the range selector lever in the (N) Neutral position. Rotate the lever counterclockwise from (P) Park through (R) Reverse.
Install the range selector lever cable to the range selector lever.
Install the lock adjustment button on the cable to the range selector bracket. Turn the lock adjustment button counterclockwise.
Lower the vehicle.
Connect the negative battery cable. Tighten
Negative battery cable to 15 N·m(11 lb ft).
1995 Chevrolet/Geo Camaro
Old Feb 13, 2003 | 10:28 AM
FWIW
I pulled the cover off the shifter and it went into park. Must have been hanging up on the cover.
Skip
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
donot_4get
Sep 14, 2002 08:03 AM
