need a LT1 carb intake
Re: need a LT1 carb intake
Originally Posted by IROC5.7TPI
I know someone that has one sitting on the shelf but im not sure if hes got plans for it or not. I'll ask him and get back to you.
thanks for lookin out IROC5.7.
no the bolt hole are different and the reverse cooling that the LT1's have would be a problem too. but yes an older style does fit on there i have an old 350 truck intake and it sits rite on there(both are 23' intakes)
gm is the only one who makes one. #24502592.
the intake doesn't have the water passages.
LT1's cools the heads first then the block(i think)
I have a standard intake i could test fit. But from what i've heard on here nobody uses's standard intakes on the LT1's.
all you have to do to use a standard sbc intake is have the outter boltholes machined because on the lt1's the intake bolts go almost straight down instead of perpendicular to the head and intake. machining is only like 70 bucks. all ports line up perfect but you can not use the middle bolt holes between the runners, it will seal fine though with no problems.
actually daddyo i know of a lot of people that would rather run a standard sbc intake on an lt1 for a few reasons. carbed intakes for an lt1 only come dual plane. also with a single plane victor jr. it will fit under a stock hood.
i'm building a motor for my Camaro(std. sbc) and the motor in my truck(85 1 ton daully)took a dump so i'm putting the LT1 in the truck so i can drive it.So fit and hood clearence etc. was not a factor i just wanted to do the swap with spending little to no money.
oldschool
Feb 9, 2016 09:21 PM
JasonD
Jul 27, 2002 08:57 PM
