Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
need a LT1 carb intake
Old May 6, 2005 | 03:20 PM
Daddyo's Avatar
anyone have one or no someone who has one or someplces to get one cheep.
thanks.
Old May 6, 2005 | 04:28 PM
IROC5.7TPI's Avatar
Re: need a LT1 carb intake
I know someone that has one sitting on the shelf but im not sure if hes got plans for it or not. I'll ask him and get back to you.
Old May 8, 2005 | 12:04 PM
Daddyo's Avatar
cool thanks, i just wanted to get one used for cheeap instead of brand new.
Old May 8, 2005 | 12:37 PM
IROC5.7TPI's Avatar
Well it turns out my buddy sold the motor he had with the intake on it.... sorry
Old May 8, 2005 | 02:44 PM
hemigtx001's Avatar
wouldnt a small block intake manifold work on the lt1?
Old May 8, 2005 | 04:19 PM
Daddyo's Avatar
thanks for lookin out IROC5.7.
no the bolt hole are different and the reverse cooling that the LT1's have would be a problem too. but yes an older style does fit on there i have an old 350 truck intake and it sits rite on there(both are 23' intakes)
Old May 8, 2005 | 08:04 PM
hemigtx001's Avatar
reverse flow means the input and out put are switched. which as far as i know really wouldnt do nethign to it.
who makes a carb intake for the lt1 motors?
Old May 8, 2005 | 08:21 PM
Daddyo's Avatar
gm is the only one who makes one. #24502592.
the intake doesn't have the water passages.
LT1's cools the heads first then the block(i think)
I have a standard intake i could test fit. But from what i've heard on here nobody uses's standard intakes on the LT1's.
Old May 8, 2005 | 08:52 PM
Dave89IROC's Avatar
hot rod hawk was using one last I heard, it is some work though
Old May 10, 2005 | 12:23 PM
Daddyo's Avatar
yeah i took my intake off my truck(85'350 motor) going to see what all needs to be done.
Old May 10, 2005 | 02:10 PM
shady93z's Avatar
all you have to do to use a standard sbc intake is have the outter boltholes machined because on the lt1's the intake bolts go almost straight down instead of perpendicular to the head and intake. machining is only like 70 bucks. all ports line up perfect but you can not use the middle bolt holes between the runners, it will seal fine though with no problems.
Old May 10, 2005 | 02:33 PM
master of a-bodies's Avatar
should be able to make a carbed vortec manifold work. I believe the have the same bolt pattern as the LT1. not sure about the water passages though.
Old May 10, 2005 | 06:53 PM
rock1501's Avatar
Looks like its not priced that bad.
http://www.gmpartsdirect.com/results.cfm
Old May 11, 2005 | 12:33 AM
shady93z's Avatar
actually daddyo i know of a lot of people that would rather run a standard sbc intake on an lt1 for a few reasons. carbed intakes for an lt1 only come dual plane. also with a single plane victor jr. it will fit under a stock hood.
Old May 11, 2005 | 12:45 PM
Daddyo's Avatar
i'm building a motor for my Camaro(std. sbc) and the motor in my truck(85 1 ton daully)took a dump so i'm putting the LT1 in the truck so i can drive it.So fit and hood clearence etc. was not a factor i just wanted to do the swap with spending little to no money.
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
