Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
M11 is less than 3 weeks away! Let's start talking about it!
Old Sep 24, 2006 | 12:20 PM
  #16
JakeRobb's Avatar
Super Moderator
Re: M11 is less than 3 weeks away! Let's start talking about it!
So if I'm running street tires, but driving around the water box, I'm not harming the track prep?
Old Sep 24, 2006 | 02:51 PM
  #17
chevy qc's Avatar
That's right. The best way to use the water from the box and not mess with the starting line is to go around the box, back into it, and roll out a foot or two. The front tires on street tire cars carry water to the line and a big problem with the rear tires on street tire cars is that they naturally clean themselves with tire speed and throw water all over the rear of the frame and wheel well causing them to drip water and other crap at the starting line. If you're using street tires and pulling through, don't to a burnout in the water, pull a foot or two out of the water before starting the smoke show.
Old Sep 25, 2006 | 04:45 AM
  #18
AL SS590 M6's Avatar
Moderator
Slick or drag radials are smooth and leave rubber on the starting line.
That's why Prostock and higher level cars do a burnout past the starting line. They could do a burn out just like we do back in the burnout box but they want to lay some fresh rubber on the start line and come back and launch on the fresh rubber.
Street tire tread digs into and peels up the rubber baring the concrete underneath which is nowhere as sticky as the VHS and rubber that was there.
Old Sep 25, 2006 | 01:11 PM
  #19
JakeRobb's Avatar
Super Moderator
I assume you mean VHT.
Old Sep 25, 2006 | 07:33 PM
  #20
RRRR's Avatar
No, you can grind up your old tapes, mix with water and spray on the track. Makes your car hook like hell!!!!!!
Old Sep 25, 2006 | 07:54 PM
  #21
ws6transam's Avatar
I'll bet!
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 23, 2014 10:33 AM
