Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
I need a mechanics help.
Old Jun 21, 2007 | 02:33 AM
POSSESSEDZ's Avatar
I just bought a project car. A 86 monte carlo ss. It runs bad the car starts ok but when you put it in gear it has a bad hesitation and would gradually picks up speed when at wot. I need some one to look at it and tell me if i need a new engine or if its some that could be fixed. I live in Warren. Please let me know i'm free all day this sunday. E-mail me at possessedz28@yahoo.com Thanks, Dave.
Old Jun 22, 2007 | 08:39 PM
1BADAIR's Avatar
if you lift from wot to 1/2 throttle does it accell quicker?
change fuel filter and/or pump
Old Jun 22, 2007 | 10:51 PM
IrocSS85's Avatar
thats a great place to start. the pump should be cheap for that car too. also make sure the air filter isnt dirty. just some basics. does that car have a throttle body inj. or is it a carb? what about plugs, dist. cap, rotor ? all in great shape? whats the timing set at? I would totally come help you out if I could, but Im up to my eyeballs in things to get done already.
if its not smoking, knocking, backfiring, the eng. should "probably" be fine, and not the problem. is it a 350 or 305?
gradually pick up speed as in the eng. is slow to accelerate or the car is slow to accelerate, but the eng. revs ok? makes a big difference.
chris
Old Jun 23, 2007 | 03:36 PM
POSSESSEDZ's Avatar
1BADAIR - It doesn't accell any quicker when i go 1/2 throttle.
Irocss85. Hey whats up you bought that 400 trans off me last year, Did you ever use it. I wish i had the money to but your car its looks awsome. If you have it next year around this time i will have the cash i work 2 jobs know to get something like that or a vette. Anyway to get to the matter at hand. Its a carbed motor 355. I just changed the plugs the wires and distributor look ok the fuel pump is a mecahnical pump.The car does have some white smoke comming out of the exhaust. if your free sunday to just come look at it and tell me what you think. I will give you $30.00 for gas. Give me a call at 231-408-1829 Thanks, Dave.
Old Jun 23, 2007 | 06:44 PM
IrocSS85's Avatar
yeah no time at all. otherwise I would. just starting a heads/cam/fuel pump install for a fella and with the normal day to day stuff goin on with that no time to go anywhere. bring it by here I'll go for a ride with you though.
as for the th400, nope, didnt use it yet. still sitting here in the garage awaiting disasembly one day. all Im goin to use it for is the case and keep the rest of the parts as spare's. got a built th400 that has a cracked case but otherwise perfect working order. all that is eventually for my 86 Iroc that Im goin to build into a drag car IF I ever do sell my 95. but for now, it sits with all the other parts I already have for it.
Old Jun 23, 2007 | 07:26 PM
1BADAIR's Avatar
does it still have cats?
Old Jun 23, 2007 | 09:54 PM
chevynutman's Avatar
good place to start is disconnect converter from y-pipe and try it with open pipe-had a v-6 that took 1/4 mile to get to 25mph at wot did tune-up and hollowed cat did burnouts all day after that---good luck
Old Jun 23, 2007 | 11:54 PM
IrocSS85's Avatar
yeah excellent idea about the plugged cats. its easy to think of when your driving a car that has the problem becuase it runs great sitting still, but start driving it down the road and the eng. just bog's.
Old Jun 24, 2007 | 09:44 PM
POSSESSEDZ's Avatar
The cats are gone it has long tubes with duel exhaust. Iam going to replace the fuel pump and see if that improves the problem.
Old Jun 24, 2007 | 10:34 PM
IrocSS85's Avatar
what kind of carb is on it? whats the timing set at? are the secondaries not opening up maybe? is the float stuck shut and not filling the bowl with fuel properly? how many miles are on the engine? is it poss. the timing chain has stretched and jumped a tooth? just some more possibilities to check for.
Old Jun 28, 2007 | 05:13 AM
POSSESSEDZ's Avatar
Whould a blown head gasket make the car run like this. I do have some white smoke comming out the exhaust. its not alot but noticeable. I think i going to forget about getting this car on the road this year and get a new motor next year.
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
