Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
hooker LT question
Old Apr 25, 2004 | 01:28 PM
TrouserSnake's Avatar
hooker LT question
any tips on getting the passenger side manifold off? a 94 lt1 car?
starter and Ypipe are off what next?
I got the front two bolts the other f*@#s wont budge when I finally do get a swivel on them...
Do I need to disconnect the stering linkage for the driver side header? do both go in from the bottem? DO i need to lift the side of the engine... Cam Is about in headers a pain in the ***
Old Apr 25, 2004 | 04:49 PM
Mike94ZLT1's Avatar
Drop the starter, that is a MUST. Make sure you have the alternator off, that def helps. It's a pain to get them off, I've done it 3 times and I hate it. One thing that would make it significantly easier is to raise the motor a few inches. Loosen the crossbolts on the motor mounts, and you can jack on the balancer, put a towel under it though. raise it up a tad, and slide the bolts out. Lift it another 2 or 3 inches and you will have plenty of room. This is also a great trick when it comes time to put the headers on. You will have to lift your car to the moon though, LT's on an LT1 without a lift sucks
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 09:07 AM
ModdedNerd
Jan 1, 2015 10:56 AM
