Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Cross drilled roters?
Old Sep 10, 2003 | 02:20 AM
  #16
limige's Avatar
kandied
what did you buy for the baer brakes? just calipers? rotors?
dual pistons? how much and where did you get them? i really need to upgrade soon.
thanks,
mike
Old Sep 10, 2003 | 08:31 AM
  #17
TreySpeed's Avatar
On permanent vacation
Originally posted by kandied91z
do they work...................yes. enough said.
and yes they have aluminum hats which is the main reason.
its not because they are cross drilled then
Old Sep 10, 2003 | 09:03 AM
  #18
91Bird305's Avatar
I am curious, if cross drilling them just hurts the performance...then why do they offer it? Thats like a company offering a more restrictive intake, it just doesn't make sense.
Old Sep 10, 2003 | 11:55 AM
  #19
TreySpeed's Avatar
but what if the intake had bling
kinda like a spoiler, slows you down. speeds 6 sec cars up.
..they were usefull back in the day when pads outgased
Old Sep 10, 2003 | 01:10 PM
  #20
ROADRAGE's Avatar
Because they look good, and contrary to Treys constant drilling of his theory, they don't hurt performance badly.
I have tried and tried to get my brakes to fade(multiple 100mph+ panic stops in a row), and it just dosent happen. I could still put my passenger into my windshield after heating the brakes if they werent buckled in. People also like to talk about the stress fractures crossdrilled brakes get.....go look at solid rotors, they get em to. The only downside I can see to crossdrilling is a possible fractional loss of stopping distance, most likely something you would never notice.
Also not Trey, that Jeff said the oem rotors still weigh 2 more lbs than the crossdrilled ones, 2 lbs of unsprung weigh is still fairly signifigant
Old Sep 10, 2003 | 01:17 PM
  #21
TreySpeed's Avatar
thats 8 lbs of unsprun weight. Pretty insignficant.
How many 100-0 stops did you do? At work 50+ stops would absolutely TEAR up a rotor beyond belief.
You have MUCH larger rotors with a MUCH greater thermal capacity.
put the pass through the window? how does that explain heat fade or not. Fade is independant of caliper strength. Heat fade will occur way after the initial "stomp"
The biggest problem IMHO is spending money to get less.
Anyone want to pay for "cool blue" TPI styple intakes for your LS1?
Cross drilling is MUCH more likely to create fractures. I dont feel I have enough knowlege in metalicurgy to explain it, but it was explained to me. Bad idea.
I love it when people try to generalize non-relative issues.
FACTS: Pay more, stop worse, weaker.
Old Sep 10, 2003 | 01:32 PM
  #22
ROADRAGE's Avatar
All unsprung weight is significant
around 10, plenty enough to see if they fade
true
Have you ever been in a car when the brakes go away? There IS no initial stomp, caliper strength or no, when the brakes completely fade, there is no initial anything except panic
There isnt much cost invloved in stock size crossdrilled rotors, and using them isn't going to hurt the performance in most situations. Believe it or not, some people like to make the car look good to(like a non-functional big block camaro hood
I am no metalurgist either, but I do know I have yet to see anyone with crossdrilled rotors that have anymore fractures than a solid rotor.
It's almost is bad as when people ask where to get something and people start spouting off about how they don't like the thing even thought an opinion was never asked for
Pay a tiny bit more, stop a couple inches later, a hair weaker, look much better
Old Sep 10, 2003 | 01:45 PM
  #23
kandied91z's Avatar
for my setup it was a no brainer.....very cost effective, stops unbelievable and looks even better.
there were no disadvantages to the setup i purchased. one of the best mods i put on the car.
as far as where to get them. detroit speedworks has pretty good prices on 4thgen equipment and you have someone local to deal with. if you want to save even more do a search on the internet. there are quite a few places that offer pretty great deals.
Old Sep 10, 2003 | 02:04 PM
  #24
TreySpeed's Avatar
why do you have center caps and valve caps on your wheels?
0-100 is much easier to 50-0-50-0, which is coincidentally more of a real world situation
true
glad we agree
This will come on a road coarse or somethng of that nature. when doing 100-0-100, but the time you get the rotors cooled and walah, no heat fade- well for the first few seconds at least. With your brakes that are so huge, this is even more so the case.
That hood saved me $100. Stock GM hood was $450. this was $350. Its also lighter.
Look harder
I'm sure he appreciates the input given here
case and point.
Old Sep 10, 2003 | 03:22 PM
  #25
kandied91z's Avatar
all i know is i have to worry more about the guy behind me then if i'm going to stop in time....it can get pretty scarry.
definately nice to know you can stop in just about any situation.
Old Sep 10, 2003 | 04:18 PM
  #26
ROADRAGE's Avatar
same reason I have 18" wheels....looks
In the real world you would never be aware of the difference between drilled and solid either. Make up your mind, we talking about max performance or not?
See last rebuttal
How much was paint and finishing? Regardless of how much it cost, you bought it for looks, you and I both know that.
Look harder
I have, when I started to see the tiny fracures in mine(2 years ago, and they are still the same size now as they were then). I called Baer to bitch. He told me that if I could find any ANY rotors with the same milage as mine had that didnt have comparable fractures, he would replace mine with 14" eradispeeds. Trust me, I looked hard.
case and point.
When you make one, i'll let you know
Old Sep 10, 2003 | 07:58 PM
  #27
TreySpeed's Avatar
See last rebuttal
Look harder
case and point.
Eric, you are instant on using generalizations. I worked at TRW and saw the data first hand. Rotor mass makes a big differance. Your *** is not a measuring device. I would love to know what justifications you have other than "i threw my passanger out the window" and "its almost the same says my ***"
If you want to stop, this is a good time to close your mouth and open your eyes/ears. I wrote a 3 or 4 page write up with justifications. If you want bling- go for it. If you want to stop, let me know.
Old Sep 10, 2003 | 09:03 PM
  #28
94bird's Avatar
OK, I'll only make one comment here. No way am I ever putting cross drilled brakes on my race car unless they're cast in like the Porsche rotors. Huge mistake for safety on a road course. They WILL crack faster than a solid rotor. You're just not seeing it for the street and almost certainly never will unless you drive so dangerously that I'd rather not be around while you're on the road.
Only 2 advantages to a cross drilled rotor for racing:
1) Less unsprung weight - get it another way that's safer.
2) Allows water to evacuate braking surface in rainy conditions. I'd rather run slotted rotors if I want to run a specific braking setup for the rain.
I'll leave it at that since this is not the right place to debate this. If anyone reading this really wants to know the background behind my statements do some searches on ls1.com in the autox/rr forum, or here in the same forum, or http://corner-carvers.com/forums/index.php etc. The list is endless.
Old Sep 10, 2003 | 09:14 PM
  #29
TreySpeed's Avatar
Mike,
I've wondered about water-
how long will water last on those rotors?
after normal driving if I hose my rotors after normal driving the water instantly boils off. Also, Under such wet conditions, you are really limited by ground : tire traction so you cant brake that hard anyway.
Old Sep 10, 2003 | 11:42 PM
  #30
ROADRAGE's Avatar
Trey, you are insistant on making it seem like crossdrilled rotors are the worst thing to ever hit the earth. On 99.9 % of the cars with crossdrilled rotors in the world, there is going to never be a time when the owner says "damn these crossdrilled rotors, I woulda been much better off with the increased performance of a solid rotor"
Have you ever looked into something a little more important to rant about?
