Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Cross drilled roters?
Old Sep 6, 2003 | 07:41 PM
mavricki18's Avatar
where is the best place to buy them for?
Old Sep 6, 2003 | 09:55 PM
AutoRoc's Avatar
KVR makes cheap cross drilled replacements in stock size. I have their rotors and pads. They seem to be good and the rotors were $150 i believe for both(silver zinc coating on em too) and the pads were $50 or so. Fasttoys.com did a GP a long time ago and that's probably the only reason I got them. Goodluck
Old Sep 7, 2003 | 04:11 PM
kandied91z's Avatar
best or cheapest...?
Old Sep 7, 2003 | 07:05 PM
TreySpeed's Avatar
On permanent vacation
best and cheapest are blank rotors.
Cross drilled rotors will significanly DEMINISH braking capabilities
Old Sep 7, 2003 | 08:47 PM
notstock4long's Avatar
so will those rotors rust like stock ones???
Or do I have to get that cadmium coating?
Old Sep 7, 2003 | 08:48 PM
kandied91z's Avatar
i never noticed any less............or more. more or less looks. the most gain i've recieved have been from a good set of pads and braided line on the stock system which worked very well for the street. that is until i put baers on the car and now i worry about the people behind me being able to stop in time.
Old Sep 7, 2003 | 09:05 PM
mavricki18's Avatar
i just got 00 vette rims and im just looking for something a little better looking than the rusty oll stock ones.
Old Sep 7, 2003 | 09:16 PM
kandied91z's Avatar
just pick up some stock replacement zinc coated versions.....
i'd say get the eradispeeds from baer but i'm sure that's more then you want to spend.
Old Sep 8, 2003 | 10:06 PM
mavricki18's Avatar
those things are seet but a little pricy.
Old Sep 8, 2003 | 10:10 PM
TreySpeed's Avatar
http://web.camaross.com/forums/showt...ghlight=rotors
Old Sep 8, 2003 | 11:16 PM
ROADRAGE's Avatar
Trey, for the love of God, shaddup.
He didn't ask anyones opinion on whether solid or crossdrilled were better. He asked what the best/cheapest CROSSDRILLED rotors were.
I happen to have crossdrilled and slotted rotors on my car, and I would be willing to bet you they stop a lot better than the brakes on your car. I doubt 99% of the people on here would ever notice the performance difference between solid and drilled anyway. We arent Indy racing or anything......and solid rotors are ugly, crossdrilled =
Old Sep 8, 2003 | 11:53 PM
IrocSS85's Avatar
dont the cross drilled rotors also reduce rotating mass? wonder how much lighter a crossdrilled and sloted rotor is then its stock counterpart?
Old Sep 9, 2003 | 09:25 PM
kandied91z's Avatar
i can tell you this much.....
my baer 13" eradispeed cross drilled/slotted/zinc two piece rotors are 5lbs lighter then my stock crossdrilled/slotted gm performance counterpart and almost 7lbs lighter then the oem version.
take a 7lb weight and swing it around on a rope....now multiply that times how ever many you put on your car. 28lbs of rotational mass is quite a bit!
Old Sep 9, 2003 | 09:54 PM
TreySpeed's Avatar
thats also 28 less pounds of mass to aborb heat.
And dont eradispeeds have aluminum hats? that might exlplain it more than the holes
Old Sep 10, 2003 | 01:56 AM
kandied91z's Avatar
do they work...................yes. enough said.
and yes they have aluminum hats which is the main reason.
