Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
AMD processor users
Old Apr 11, 2003 | 06:32 AM
Grover's Avatar
Exclamation AMD processor users
You guys using AMD processors, when you power on the computer does it say the exact speed of your processor? I bought a AMD Athlon XP 2700+ according to what it said on the packaging. But when I installed it and powered on it says Athlon XP 1500+ on the screen. The MOBO found my 1GB of Corsair XMS memory just fine.
Old Apr 11, 2003 | 06:38 AM
Black Sunshine/ 00SS's Avatar
Mine does.
Old Apr 11, 2003 | 06:48 AM
DJCobol's Avatar
Tips:
1: Flash your BIOS. You could have an outdated software package that doesnt support your chip speed yet.
2: Check your BIOS settings. I can underclock my chip from within the BIOS, that may be your case.
3: Check your FSB speed too.
Becca_007's Avatar
Mine says 2000XP when I boot, and that is what I have... for now!
Old Apr 11, 2003 | 11:40 AM
Grover's Avatar
Originally posted by SinisterSyclone
Tips:
Thanks Chris!! I downloaded the BIOS revision that supports the 2700+. I had left the BIOS settings at default, but I will check to see what they need to be set at for the processor.
How do I set up my CDRW drive to be a bootable drive? It wouldn't work as a boot drive last night so I had to download the XP setup floppies from Microsoft's website.
Old Apr 11, 2003 | 11:47 AM
Rodrigues's Avatar
For the CPU you need to go into advanced chipset options and correct the set the multiplier for your CPU (In your BIOS)
And for your CDRom, you need to go into your BIOS and change the boot sequence so cdrom is first instead of your floppy disk drive.
Old Apr 11, 2003 | 02:47 PM
Timberwolf's Avatar
I got rid of my XP 2000+ in exchange for a XP 1700+. Right now it's running at 2200+ (1.8ghz) and CPU temp is a balmy 35C. As soon as my other mobo comes back from RMA I'll push it up to around 2500+ or so...
Chad, I would guess it's all in your FSB and multiplier settings
Old Apr 11, 2003 | 03:29 PM
Grover's Avatar
I am going to start by upgrading the BIOS, since there are new versions available.
If that doesn't work, then I will look at the FSB & multiplier.
Old Apr 12, 2003 | 01:53 PM
Timberwolf's Avatar
did ya get it figured out man?
Old Apr 12, 2003 | 02:44 PM
Grover's Avatar
Yep, I had to upgrade the bios and then change the processor frequency from 100Mhz to 166Mhz in the bios and now is says 2700+ when I boot up.
Just got to finish loading everything.
Old Apr 12, 2003 | 03:21 PM
Timberwolf's Avatar
good deal. I'm waiting on my soltek to come back from RMA so I can set the FSB to 200
Old Apr 12, 2003 | 05:22 PM
Grover's Avatar
Okay, I got everything loaded back up and ran the 3Dmark2001 SE with everything in the default settings and it came out like this. The processor is Athlon XP 2700+
Not bad huh
Old Apr 12, 2003 | 07:29 PM
Timberwolf's Avatar
"The project id is not valid - please check the URL."
Old Apr 12, 2003 | 09:17 PM
Grover's Avatar
That's weird it worked for me, anyways 14531 marks was the score.
Old Apr 13, 2003 | 12:14 PM
Grover's Avatar
It said something about the project couldn't be published because of an undetected component, which was my AMD Athlon XP 2700+ processor with 333 FSB. Anyway here are the results:
System Configuration
Operating System Microsoft Windows XP
DirectX Version 8.1
Mobo Manufacturer ASUSTeK Computer INC.
Mobo Model A7N8X2.0
AGP Rates (Current/Available) 8x / 4x 8x
CPU Unknown 2163 MHz
FSB 166 MHz
Memory 1024 MB
Graphics Chipset ATI RADEON 9700/9500 Series
Driver Name RADEON 9700/9500 SERIES
Driver Version 6.13.10.6200
Video Memory 128 MB
Program Version 3DMark2001 SE
Resolution 1024x768 32bit
Texture Format Compressed
FSAA Disabled
Z-Buffer Depth 24bit
Frame Buffer Double
Rendering Pipeline D3D Pure Hardware T&L
Test Results
3DMark Score 14531 3D marks
Game 1 Car Chase - Low Detail 196.1 FPS
Game 1 Car Chase - High Detail 71.1 FPS
Game 2 Dragothic - Low Detail 280.8 FPS
Game 2 Dragothic - High Detail 147.7 FPS
Game 3 Lobby - Low Detail 185.2 FPS
Game 3 Lobby - High Detail 82.2 FPS
Game 4 Nature 94.5 FPS
Fill Rate (Single-Texturing) 1701.2 MTexels/s
Fill Rate (Multi-Texturing) 2506.5 MTexels/s
High Polygon Count (1 light) 63.3 MTriangels/s
High Polygon Count (8 lights) 13.8 MTriangels/s
Environment Bump Mapping 129.8 FPS
DOT3 Bump Mapping 184.1 FPS
Vertex Shader 190.4 FPS
Pixel Shader 190.3 FPS
Advanced Pixel Shader 187.8 FPS
Point Sprite 35.2 MSprites/s
marlar98
Sep 12, 2018 07:18 AM
2QUIK6
Sep 17, 2016 02:31 PM
maverickmk
Sep 1, 2015 09:17 PM
FryedClutch
Sep 1, 2015 08:24 AM
mrwz28
Jul 8, 2015 09:11 PM
