Middle Atlantic New Jersey, New York, and Pennsylvania
Water + Oil = Bad
Old Sep 29, 2007 | 09:28 PM
Schweet97Z's Avatar
Water + Oil = Bad
So a friend of mine bought a roller with the top end of the motor off, figureing we were going to use my stock parts to get it running, well i pulled the oil pan drain plug, and nothing but crystal clear water cam GUSHING out of the pan. 4 gallons later and ripping the entire motor out, this is what we got...
Old Sep 30, 2007 | 07:25 AM
Projectz28's Avatar
Moderator
mmmmm yummy!
thats what happens when it sits out in the rain
easiest thing to do Harold... put something under it to catch the cleaner... get a sprayer like a weed sprayer and fill it with solvent. Spray it down untill all the sludge is gone. The blow it off with compressed air and then take it appart for inspection.
Old Sep 30, 2007 | 08:10 AM
Schweet97Z's Avatar
we are doing that today. yesterday we pulled a cap off the connecting rod, and nothing was rusted. so everything is getting cleaned up and sent to the machine shop. the block needs atleast honed.....
Old Sep 30, 2007 | 10:01 AM
Projectz28's Avatar
Moderator
That sludge lookin stuff is actually pretty good a protecting what it touches. Obviously its to a certain point... if you submerge it in water you done but the mix will tend to cling to everything and keep it in decent shape.
Old Sep 30, 2007 | 07:37 PM
Schweet97Z's Avatar
well i was in shock to see everything on the motor actually wasnt as bad as i expected it to be. there is def. alot of work that needs to be done. stock cam is shot, lifters, and the cylinder walls needs honed. But the crank didnt look to bad. im going to let him decide what he wants to do, but a 355 with a good set of rods and pistons is probably what he is going to do. how much hp can a stock crank handle?
Old Sep 30, 2007 | 08:33 PM
Projectz28's Avatar
Moderator
N/A the stock crank can go pretty far. I've seen 600 hp on stock cranks. Reworked stock cranks but they were still stock...
Old Oct 1, 2007 | 07:51 AM
Schweet97Z's Avatar
what about a heads/cam car with like a 150 shot?
Old Oct 1, 2007 | 09:19 AM
Pampered-Z's Avatar
BANG!
Old Oct 1, 2007 | 09:30 AM
Schweet97Z's Avatar
lol ok....
Old Oct 1, 2007 | 08:05 PM
Projectz28's Avatar
Moderator
that depends on what heads and what cam...
SR with max effort race ported LT4's/AFR's/TFS heads.... nope, I wouldnt trust a stock crank.
small HR cam like a hot cam and basic port job and I say go for it...
BTW, Harold I got your message. I'll call ya tomorrow.
Old Oct 2, 2007 | 07:57 AM
Pampered-Z's Avatar
And I say,,,,
BANG!
OK, maybe a 150 wet kit with all the right stuff, like sensors and tuning, then MAYBE?
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
