Middle Atlantic New Jersey, New York, and Pennsylvania
emissions
Old Jan 19, 2004 | 04:02 PM
Mike383LT1's Avatar
emissions
hi jeff how many miles a year do you drive your car? im in the same boat i was told as long as the emissions are on the car you will be alright does not nessasarly mean in the factory locations
Old Jan 19, 2004 | 04:04 PM
Mike383LT1's Avatar
emissions
sorry jeff ment to post a reply not a new thread so this is your answer
Old Jan 19, 2004 | 06:33 PM
Pampered-Z's Avatar
If you drive less then 5,000 miles in one year the car is exempt. They do a visual to verify the cat and AIR are still installed, then they put an exempt sticker on for the emmis.
Inpection must be at least 365 days, anything less and they must use the sniffer.
John
Old Jan 19, 2004 | 07:28 PM
GetaZforgetGT's Avatar
Cats aren't an issue...
I plan on buying Cats with the air hookup on them and plumb the air pump to it since the Jethot LT I bought don't have the hookup.
The egr setup is going to be a pain in the a$$ but I think I have an idea. I just need to find a shop that doesn't look really hard.
I drove my car about 7000 miles last year but staying under 5000 really wouldn't be much of an issue.
Old Jan 24, 2004 | 07:36 PM
ledfootz28's Avatar
i only put 788 miles and i have proof from my old emissions paper.im in the suburbs outside of philly so prey to god im exempt.im goin for the test in april so i ll see how it goes
Old Jan 29, 2004 | 09:37 PM
CamaroRSguy's Avatar
Do you know if it'll trick anything if you have your computer programed to ignore EGR not being there anymore... this is my current dilema.
Old Jan 30, 2004 | 10:19 AM
They still do the visual inspection so if you have everything there then you should be fine for that part.
My understanding is that as long as you aren't throwing any codes you will be fine when the hook you up to the Emissions computer.
Old Feb 2, 2004 | 10:04 AM
DT's Avatar
DT
use ls1 edit to remove the codes when you remove the air or egr. you could leave the egr in place just dommy it up so it looks like it goes in the intake.
Old Feb 3, 2004 | 08:14 PM
ibanez6rg's Avatar
What would be the point in that?
Old Feb 3, 2004 | 10:09 PM
ledfootz28's Avatar
well if ur going to be exempt from emissions with milage under 5k they dont scan it to see what codes are being thrown,its just basically a visual inspection.
Old Feb 4, 2004 | 08:00 AM
DT's Avatar
DT
To pass the visual inspection because we dont live in the middle of nowhere, Wilmington, Oh?
Old Feb 4, 2004 | 09:14 AM
ibanez6rg's Avatar
The only reason to get rid of the stuff is to get out of the way. There is no performance gains.
Old Feb 4, 2004 | 02:41 PM
hurricaine418's Avatar
gains
small gain if you go to an offroad y-pipe or gutted cats for visual. i have gutted cats, electric cutout, and the sims for the cats. nice little gain and very loud when i open the cutout.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
