emissions
emissions
hi jeff how many miles a year do you drive your car? im in the same boat i was told as long as the emissions are on the car you will be alright does not nessasarly mean in the factory locations
If you drive less then 5,000 miles in one year the car is exempt. They do a visual to verify the cat and AIR are still installed, then they put an exempt sticker on for the emmis.
Inpection must be at least 365 days, anything less and they must use the sniffer.
John
John
Cats aren't an issue...
I plan on buying Cats with the air hookup on them and plumb the air pump to it since the Jethot LT I bought don't have the hookup.
The egr setup is going to be a pain in the a$$ but I think I have an idea. I just need to find a shop that doesn't look really hard.
I drove my car about 7000 miles last year but staying under 5000 really wouldn't be much of an issue.
They still do the visual inspection so if you have everything there then you should be fine for that part.
My understanding is that as long as you aren't throwing any codes you will be fine when the hook you up to the Emissions computer.
Originally posted by DT
use ls1 edit to remove the codes when you remove the air or egr. you could leave the egr in place just dommy it up so it looks like it goes in the intake.
To pass the visual inspection because we dont live in the middle of nowhere, Wilmington, Oh?
sleeperZ96BT
Sep 9, 2015 08:28 AM
jgeorger
Oct 24, 2002 09:31 PM
