Altinator Relocation
Well while the motor is out of the car Im deleting the A/C and want to do an altinator relocation. I do however want to keep the powersteering. Is there a bracket out there that will allow this? Brian (ProjectZ) Im pretty sure you have your altinator relocated. Which bracket did you use? Do you still have your power steering? Anyone else that would like to chime in please do.
I used the SJM kit. Not bad but it is lacking in the stability area. I only have an alternator, no PS or a/c. The problem I saw with the kit was that under hard acceleration the bracket has a tendency to torque forward. This causes the belt to become misaligned and started to chew up the front leading edge of the belt because the belt would walk forward and jump 1 rib. Never threw it off but not what I call reliable. When the new motor went in I fabbed up a small round bar with 2 tabs that bolted the rear of the alternator to the motor mount to prevent it from twisting up under fast acceleration.
IMO you can make one easily if you have the tools. If not the kit is just ok. It really needs another rear support to hold it straight. I assume any kit similar indesging to the sjm is going to have the same problem.
Harold,
Look at what this guy did. http://www.cardomain.com/ride/2108416 I would wait until you get the car, tubular k-member and solid motor mounts from me. Then you can accurately mock it up on a stand. Talking from experience, there is no car that sucks more to steer than a car w/ ps that is not hooked up.
Give me a call.
Later,
Steve.
Give me a call.
Later,
Steve.
It is fine going down the track and even turning off. It gets kinda tuff driving in pits. I don't want to think of driving that way on the street. I do have a spool and can steer by a little stab on the gas peddle. Much easier to slide the tail end around than turn the wheel.
Do a "search" on the "LT1 Based Engine Tech" forum. There is a thread there showing pictures of a relocated alternator, with power steering. The "wrap" on the pullies looks a little skimpy, but the original poster indicates he has not had a problem with the belt slipping.
last I heard they stopped making that bracket you are talking about.
http://www.speedinc.com/index.cfm
How about this, we moch up the following:
Delete A/C and move the PSP down to where the A/C was, We can probably cut up the stock unit, and make it fit and clean up the top of the engine. Then relocate the alt to the other side ALA a supercharger type mount.
Make the pump and ALTERNATOR <- DAMN KIDS
mount high enough to clear the top of the crank pulley so the belt will wrap around all the pulleys enough to not slip and a SC type tensioner pressing downward on the belt.
We should be able to mock up a mounting plate and have Antz cut one out with his CNC machine!
Option 2: relocate the Alt and rig up an electric PSP pump from an old Feiro??
mount high enough to clear the top of the crank pulley so the belt will wrap around all the pulleys enough to not slip and a SC type tensioner pressing downward on the belt.We should be able to mock up a mounting plate and have Antz cut one out with his CNC machine!
