ZO6 MAF....Worth it?
Old Jul 6, 2003 | 11:48 PM
Black_Z28's Avatar
My MAF is on it's way out, so I'm in need of a new MAF. I saw the ZO6 MAF at LS1speed, and saw it was a good price. Is this a pretty decent MAF, would it throw any codes? Would it be an improvement over stock? I know it's bigger, but would it make a difference? Thanks.
Old Jul 7, 2003 | 12:38 AM
InjectedSS's Avatar
Re: ZO6 MAF....Worth it?
WASTE OF MONEY!! just stick with the stock one! all i would do is descreen it! some just leave them BONE STOCK but i would AT LEAST descreen that bish but DONT port it!
Old Jul 7, 2003 | 06:52 AM
97FormulaWS-6's Avatar
For REPLACEMENT purposes the Z06 one is good, I mean it's 1/2 the price of a GMS or GM Stock replacement, well the LS1speed is 1/2 the price.
It's a larger MAF, and will flow more air, but if you buy the one from LS1speed.com it's prettymuch plug and play. You can also get the GM Replacement part but then you will need your PCM programmed and a pigtail adapter.
Old Jul 7, 2003 | 11:22 AM
Da_Dark_Z28's Avatar
That is the route I took. The ZO6 MAF was cheaper than stock, and it works with no problem at all. If your MAF is going out, I highly recommend it.
Old Jul 7, 2003 | 02:44 PM
JeffK95Z's Avatar
do NOT de-screen the MAF... its a complete waste of time and effort...
if ANYTHING, it'll hurt you... 0, read 0, 0000 gains to be had...
search and learn
jeff
Old Jul 7, 2003 | 02:46 PM
Antz97ZNJ's Avatar
If u need a new one then yes, but to gain performance dont waste your money
Old Jul 7, 2003 | 02:56 PM
teke184's Avatar
i installed one on my Z for about a month (till i totalled it). it seemed top make a difference on the top end...didn't notice anything around town. it threw no codes and caused no hesitation problems or anything like that.
for the price compared to stock replacement...not a bad idea
got mine 2nd hand but brand new...so it was a decent deal for me.
oh and i already had a ported/descreened unit (GMS composite maf ends).
Old Jul 7, 2003 | 03:14 PM
Black_Z28's Avatar
Does the ZO6 MAF fit well on the stock piping? Isn't it 3.5" while the stock stuff is 3"? You guys that have the ZO6 installed, did it install fine with the stock materials??
Old Jul 7, 2003 | 03:46 PM
96speed's Avatar
Its 85mm. The stocker is closer to 74mm, so its a bit larger in diameter. I have a moroso CAI, and the rubber CAI-MAF coupling piece stretched enough to fit on the Z06 MAF fine. The 1LE elbow with fit the larger MAF as well.
Its a tight fit, but it works fine.
Ryan
Old Jul 7, 2003 | 06:30 PM
I have a K&N CAI. I used a rubber 4" to 3" reducer, to connect the CAI to the MAF, then the rubber piece that came with the MAF slide over the 3" of the reducer and the end of the MAF. The elbow slide over the other end of the MAF. No problems at all so far, no codes or anything. I do agree though don't descreen it, my stock MAF was descreened and I had a bad idle and stumbling problem.
Old Jul 7, 2003 | 07:11 PM
Well, I'm not going to get into the descreening thing here... no one listens to me about it anyway but for MOST application I wouldn't recommend removing the screen....
I have... but I have reasons on my intake setup to warrent the removal....
also the true '02 Z06 MAF does NOT come with a screen... I wonder why?.... look at the intake track... look at a WS6 intake track... notice a similarities? that's why I removed my screen...
But most CAI's should leave in the screen.... but I know that people will argue that point... but hey... my BS in Engineering I guess means nothing
whataretheodds
Apr 22, 2003 03:47 PM
C.Bachmann
Mar 29, 2003 04:05 PM
Mr. Nice Guy
Dec 21, 2002 07:25 PM
JasonD
Oct 30, 2002 03:36 PM
