Re use heat shields on plug change?
Old Jul 7, 2003 | 06:28 PM
1msfyter's Avatar
I just installed my MSD's 8.5 , should I re use the original heatshields on the the rear plugs? If so they have to be bent out to fit. Feedback?
Old Jul 7, 2003 | 06:40 PM
96z's Avatar
96z
I never did and havent had any problems with the boots. I did burn the #7 wire though b/c I didnt wire it correctly.
Old Jul 7, 2003 | 06:41 PM
Dr.Mudge's Avatar
No reason not to, if you can get them to fit.
Old Jul 7, 2003 | 07:19 PM
TA Dreaming's Avatar
i just did mine last night and i reused and rerouted the new wires through all the factory heat shields and looming. i used msd 8.5s as well. just bend it out slide the new boot into it and clamp it back on so its snug and wont fall off. as hard as that number seven wire is to do following factory routing i sure as hell didnt want it burning up. Trey
PCLZ28
Dec 24, 2015 05:19 PM
jasonduaine
Mar 7, 2015 09:44 AM
rjc1629
Jan 27, 2015 10:46 AM
Jan 23, 2015 01:13 PM
