Z28 Lt1 TPI
Z28 Lt1 TPI
i recently purchased a 1987 z28 camaro. Lt1 tpi engine. i have a problem. yesterday i took the car to a car wash. i sprayed the engine with degreaser then with the pressure washer i removed the degreaser. after that the car started fine but when i accelerate it gets to a certain rpms and suddently the engine just gives out like if i was chocking the engine. I tryied everything i could to clean out any water in the distributor cap. still no luck any ideas.
It can't be an LT1 and a TPI engine. They are two different motors. The TPI would be correct for your car.
I'd guess you got something wet. Just start checking stuff. Not much help.
Try posting in the third gen section
huh!!!!!!
well it says Tuned Port Injection so i guess is not an LT1. i tryed to clean every electronic on view but i think i'm missing something. my friend told me that i have a combustion problem. The injectors are a little loose meaning that you can swing them side to side. I'm thinking this could be a problem.
Ok,
well i didn't think of that but of the compressor i tryed drying it off with the compressed air but it only work a little. got little more rpms. i also started the engine and let it ran for about 30 minutes and still no luck.
Jul 4, 2005 05:00 PM
30thZ286speed
Aug 3, 2002 04:54 AM
