Z won't Start sometimes
Old Jul 27, 2004 | 01:06 PM
95zragtop's Avatar
My 95 Z-28 has run great for the last five years. About two months ago it started hesitating in the lower rpm’s. I used some sea foam and it seemed to help but not fix my problem. I changed the plugs, air filter, pcv have not done the plug wire’s. Now two weeks ago it. would not turn over (first thing in the morning). Left it at home got a fuel filter and when I got home it started right up? Changed the fuel filter. Couple days ago would not start again but in the afternoon? Had the fuel pressure checked it was 41. Mechanic says it’s running great each of the three times I have taken it to him? (computer shows no problems). Has 94 k on it. Please help
Old Jul 27, 2004 | 01:52 PM
GreenDemon's Avatar
Re: Z won't Start sometimes
You are not alone
Ever walk out to your car, put the key in the switch, and wonder if someone stole your battery?
There is no simple solution to this one.
If I keep this car for more than a couple years I'm buying an AFTERMARKET harness. And I'll find a way to ditch GM's ignition and charging system completely...
Old Jul 27, 2004 | 06:23 PM
95zragtop's Avatar
thanks for the reply Just thought of something, a couple of times in the last two weeks when it has started it sounded like it was running on four cylinders. Could this be a opti? clears up when get on the gas and go about 100 feet?
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
