Yet another question on Opti
Old Aug 12, 2005 | 06:17 AM
Roscoe267's Avatar
Had a low rpm miss on my car, usally under 3000 rpm.. Changed out the plugs, checked all wires which ended up not to be the case, even changed out the coil just to be on the safe side and still the miss..Had a bud of mine run a dio useing a snap on code scanner, and read that there was an intermittent missfire in #5 , and #6.. Now mind you no codes were set and the car ran fine 1 second then the missfire just appeared the next.. The car is a 97 Camaro and has 62,000 miles on it and has the stock opti in it.. So my question to guys is, is it the cap and rotor, or the whole opti assy? Any help would be helpfull
Old Aug 13, 2005 | 01:56 AM
Roscoe267's Avatar
Re: Yet another question on Opti
Anybody have any suggestions? Any helpfull hits or advice? Please opti gurus let me hear from you
Old Aug 13, 2005 | 02:40 AM
glock22_40's Avatar
Can't say for sure, but I can say that I had the same exact problem with the intermittent missing and no codes being set. I am in the middle of changing my opti right now and the problem I had was someone had put a new cap and rotor on my old opti( I know this because the cap was a vented new style cap on my first gen opti) and one of the screws holding the rotor on had come out and was bouncing around inside.
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
