yellow opti wire?
Old Jun 24, 2006 | 03:14 PM
flusz28's Avatar
yellow opti wire?
i have a 1994 z28 and the letter C on the opti harness that plugs into the pcm harness is a yellow wire. with the key turned to the run position this wire is hot with a test light. i think my opti quit on me and i remember a year ago reading bout this meaning its a bad opti of the wire was hot? is this correct??
Old Jun 25, 2006 | 12:55 PM
Re: yellow opti wire?
"C" is the "ignition feed" wire, and shows up as red in all but one of my wiring diagrams. That wire supplies +12V to the Opti.
Old Jun 25, 2006 | 08:58 PM
flusz28's Avatar
Injuneer did you read the pm i sent you? when i push the gas pedal and pumped it the car was bout to start till my starter wouldn't shut off so i cut the key off and unplugged the battery. a guy on another board said he car acted like that and just cranked and it was his IAC valve....
warmeck
Mar 22, 2015 06:43 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
