yellow crap
Old Dec 8, 2008 | 08:14 PM
jtarp's Avatar
yellow crap
I was installing my new cold air intake and i notice some yellow gunk in and around the blades of the trottle body...any ideas?
Old Dec 8, 2008 | 09:36 PM
Possibility - Oil pulled backwards through the PCV air supply hose between the passenger side valve cover and the throttle body, combined with moisture in the air condensing on the cold blades, forming an oil/water emulsion. Unless of course you got carried away lubing the throttle blade bearings at some point in the past.
Check the hose coming from the valve cover and look under the cover plate on top of the TB for oil buildup.
Old Dec 8, 2008 | 11:02 PM
jtarp's Avatar
Thanks..I will check that in the morning.
magman
Apr 15, 2016 03:08 AM
jayblev95
Sep 26, 2015 09:44 PM
colts0455
Sep 22, 2015 02:03 PM
Sep 18, 2015 03:46 PM
KYWes
Aug 10, 2015 07:03 PM
