YEAH! Just got my motor mounts!
Old May 30, 2007 | 07:27 PM
Heatmaker's Avatar
Advanced Member
Talking YEAH! Just got my motor mounts!
I have no idea why, but I'm excited to install these things. More so than the cam I put in... Maybe it's because I'm tired of seeing the motor bouncing around I dunno.
Well I heard installing these urethane mounts were fun... can't be worse that installing the upper and lower A-arm bushings with the torch and all... now that was a good week.
Old May 30, 2007 | 07:28 PM
2000GTP's Avatar
Mine have been sitting in the box in the garage for almost two years now. I'm not looking forward to installing them, I'll probably just wait till the motor has to come out.
Old May 30, 2007 | 07:30 PM
Heatmaker's Avatar
Advanced Member
yep... but life is always easier with a Tube K-member.
Old May 30, 2007 | 07:32 PM
2000GTP's Avatar
I've been eyeing one of those, but for the pricetag, there are other mods I would rather focus on. If I can find one used for a decent price, then I will definitely reconsider.
Old May 30, 2007 | 08:48 PM
ttop1986's Avatar
Mine were a pain in the ***. Have fun.
Old May 30, 2007 | 10:44 PM
Z-RATED94's Avatar
I'm excited for you too. I'm very glad this upcoming little project makes you happy, have fun.
Old May 31, 2007 | 05:28 AM
'94 Bad A Z28's Avatar
I think I really need new motor mounts in my car.
Old May 31, 2007 | 08:12 AM
gt_biker13's Avatar
I cant remember them being too hard compaired to installing headers. Make sure you have a friend and use a long pry bar when puting the mounts in to move the engine around. The hardest part is just lining up the bolts.
Old May 31, 2007 | 10:19 AM
Z-RATED94's Avatar
Yeah, just like installing headers, you have to be a little creative.
Old May 31, 2007 | 03:20 PM
Don 97 SS's Avatar
I like all the benefits of poly mounts, with the exception of the added vibration. I almost wish I had used new oems instead of the polys. (I did say, almost )
Old May 31, 2007 | 07:55 PM
turnin20s's Avatar
Yeah they make the car vibrate pretty bad, but I'll take that over some sloppy stockers anyday.
You might as well upgrade your tranny mount too while you are there, but thats up to you.
Installing mine was a pain in the ***, and I had the motor and K-member out of the car. Getting the motor to line up with the bolt holes was just stupid, I'm just glad the motor was out of the car so I could actually have some room to work.
Good luck
Old May 31, 2007 | 08:52 PM
'97SS's Avatar
They did wonders for me. No vibrations and my y-pipe stopped slamming into my car. Not too bad to install if you just take your time.
Old May 31, 2007 | 08:57 PM
mobleman's Avatar
Same here, new rebuild and used poly motor and transmission mounts. Actually smoother than it has been for the past few years and can feel no added vibration.
Old May 31, 2007 | 08:59 PM
wrd1972's Avatar
The poly mounts were a SOB to install when the K-member w/engine were out of the car and being assisted by a cherry picker. I can not imagine trying to install them with the engine in the car. The hardest part is aligning everything close enough to get bolts in, the poly is so much stiffer than the rubber and it does not give.
I did not like the vibrations from the poly mounts so I went back to rubber when the engine came out the second time. They are definitely the way to go if your racing or making crazy power.
Old Jun 1, 2007 | 10:25 AM
2QUIK6's Avatar
With a near stock cam, you should not notice any added vibrations. I have a cam similar to your and having both sides poly was a little much for a daily driver so I switched the passenger side out ( It hink is was the ps side..) for a OEM one and all is good now...not much added vibration and no motor roll either.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
sleeperZ96BT
Sep 5, 2002 08:03 PM
bradyb
28
Sep 4, 2002 12:57 PM
Nostang 96z
Aug 31, 2002 12:01 PM
