running rough...
Old Jun 1, 2007 | 08:53 AM
FIREHAWK #7's Avatar
running rough...
a couple of days ago it rained really bad.... all the streets were flooded but i did not drive through them. Earlier that day i had changed out a bad o2 sensor. I got home ok, and the last couple of days the car has been running a lil rough.
Im guessing the opti got a lil moisture insdide; when i run the car at first it idles ok, but as soon as i head on the road and put it on a load, it bogs, and sometimes throws a misfire SES light (flashes).... it goes away after driving it for a couple of minutes...
so what do you guys think??? I think the opti got a lil moisture inside, anyway that i can take it out?? ITs a 96 so its a vented opti. BTW the GM opti is less than 2 years old.
Old Jun 1, 2007 | 10:49 AM
2000GTP's Avatar
It could be opti related, but it could also be another part of the ignition system such as the wires that are at fault.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
