y-pipe thingy problem
Old Jul 29, 2006 | 09:18 AM
nodnarb481's Avatar
Yea so ive got the y-pipe hitting the floor problem with my longtubes. Neat. IT does the rumbling against it under load and when the transgo shifts to second. BAM big hit under there. Now i know of crushing the floor and i know of wrapping something around it. But heres my questions. Could this set off the knock module and cause timing retard? If so would getting the LT4 knock module fix that? and WHAT kind of wrap and WHERE can i get it?
Old Jul 29, 2006 | 10:41 AM
deputydough's Avatar
Re: y-pipe thingy problem
yes, it can. i think wrapping would be a band aid for your problem. do some searches. i have seen this covered before. also, i don't think the lt4 module will help with that. find out why it is hitting the car and fix it.
Old Jul 29, 2006 | 10:48 AM
matLT1's Avatar
IMO opinion crushing the floor is a very half--s/ghetto fix. There are a few things that you can try. One is to loosen (not remove!!) all of the bolts (boths headers, flanges @ y-pipe and where it meets the catback) and make sure that the rear of your driver side header is as low as it will go. This bought me another 1/16-1/8 of an inche. You can also try grinding slightly at the crossmember (don't go too crazy) because that is where it is more than likely hitting. If it is only hitting on a very small patch of the pipe (an inche or so) one good tap on the pipe with the hammer would probably give you all the clearance you need.
Old Jul 29, 2006 | 11:27 AM
Sleeper_Z's Avatar
Another thing, what transmission mount are you running? If your running the energy suspention mount AND you have the metal shim plate installed you should remove the shim and it will give you some more room as well.
Jeremy
Old Jul 29, 2006 | 02:34 PM
1racerdude's Avatar
If ya fix the floor right it ain't getto.
I cut the sides out of the brace and heated it and bent it up to the floor and welded it. Repainted it and it looks pretty good.
I have 2 x 3-1/2 to 4" out the back and IT won't hit on every beer can it runs over.
Beating on the pipe for clearance is getto and interrupts flow.
Old Jul 29, 2006 | 04:24 PM
nodnarb481's Avatar
i think i might just stick a jack under there and crush that lowered floor part up so its just not there anymore.
Old Jul 29, 2006 | 07:16 PM
z2894droptop's Avatar
You can put a piece of heater hose between it and it will be good. I done mine like that about years ago and I haven't had anymore problems out of it.
Old Jul 29, 2006 | 07:22 PM
matLT1's Avatar
I agree, but what I was getting at is that just going under there and pounding away at the undercarriage of your car just doesn't seem like the best approach.
Old Jul 29, 2006 | 08:17 PM
1racerdude's Avatar
Yep,ya got that right
This was before welding and finishing. The black paint is to keep it from rusting down here.It was painted gray.
Old Jul 29, 2006 | 10:02 PM
Chevycobb's Avatar
just take a real good look at it before you go banging away though. I have a similar problem. My y-pipe was made up when my motor mounts were bad, now with new mounts my y-pipe rests agaist the k-member and vibrates on it...really annoying but will be fixed soon.
Old Jul 29, 2006 | 11:37 PM
nodnarb481's Avatar
what is the purpose of that part of the undercarraige? From the look of the picture it looks useless. If this is the case ill probly just crush it up a little bit and be done. Maybe paint it a little if i mess it up too bad
Old Jul 29, 2006 | 11:41 PM
1racerdude's Avatar
It strengthens the floorboard for the front of the seat is the only thing I could figure. That is why I did it that way and rewelded it.
Now if ya figure on not being in a head on or hitting a post beat away.
R@mpage
Apr 20, 2015 10:02 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Fatdog2
Jan 24, 2015 12:08 AM
Mike94ZLT1
Jul 31, 2002 01:50 AM
