XE224/230 Guys inside plz!
Old Jan 27, 2004 | 06:41 PM
  #16
InGodITrust's Avatar
I was looking at your sig. Why didn't you go with the 1.6 rockers?? Just out of curiousity.
When I built it they only had 1.52 roller rockers in stock and I REALLY wanted to get it done!!! I don't think there really is a whole lot of difference, power wise, from 1.5 to 1.6 ratio!
If I had to do it over I would go with 1.6, though!!!
Old Jan 27, 2004 | 07:45 PM
  #17
LimitedEd1LE's Avatar
With 1.6 RR's you get more lift and duration. With the 224/230 and 1.6 RR's you get .536"/.544". I beleive the 1.5's are around .510"/.520" or something like that. The longer the valves stay open the more power you will get.
Old Jan 27, 2004 | 09:25 PM
  #18
Yeah, that's true. They are 1.52 ratio. But I've seen it argued on this board that going from 1.5 to 1.6 isn't really worth it!...that is if you already have 1.5 installed!
Old Jan 27, 2004 | 09:52 PM
  #19
Yea if I already had the 1.5's in I probably wouldn't change to 1.6's. It's just not worth the money.
Old Jan 27, 2004 | 11:54 PM
  #20
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
LimitedEd1LE you wont get any more duration from the 1.6's. duration is referenced to the cam lobe. obviously the cam lobe isnt changeing because of a rocker swap. i am just recycling either a shoebox or injuneer reply i cant remember which.
Old Jan 27, 2004 | 11:56 PM
  #21
endobong's Avatar
can you use that cam without porting stock heads? just temperarly
Old Jan 28, 2004 | 11:34 AM
  #22
Sorry I meant to just say intake and exhaust lift. It was late and I had a brain fart. Haha
Old Jan 28, 2004 | 11:45 AM
  #23
Red96Lt1's Avatar
Yes, you just won't see the full potential of the cam untill you do some head work.
Old Jan 28, 2004 | 11:56 AM
  #24
QCKZ28's Avatar
12.51 at 115.38 with a crappy 60' (2.06) raceweight 3540lbs
with my setup i should be pulling 1.6-1.7 sixty foots this season.
hopefully running some 11.9's
jesse
Old Jan 28, 2004 | 12:47 PM
  #25
turbo_Z's Avatar
I have that cam as well and for the most part i like it. Only difference is I had mine ground on a 110 LSA instead of the advertised 112. Given the opportunity to do it over again id probably just got with the same cam on a 112 or possibly something slightly larger from CM. Reason I say that is I have some cam surge down low that ive done my best to try and clear up to no avail but then again I do need 4.10s. No track times and no sound clips.. sorry.
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
