xe 224/230 and lift number question
Old Jun 12, 2003 | 10:46 PM
RedTransAm21's Avatar
I'm looking at the xe 224/230 cam from combination motorsports. the three options I'm looking at have different lift numbers at: .536/.544, .560/.598, and .605/.622 all with 1.6 rr's. I have stock heads right now but they will be ported soon, I have long tubes and true dual exhaust with intake and all free mods, I will also get tuning when I get the cam in. I don't really care about gas mileage or driveability, it will mostly be a weekend driver. all I want is the most power, so which will give me that and what are the differences that I would see with those different numbers. thanks in advance.
Old Jun 12, 2003 | 10:54 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i'm going with the 605/.622 myself-
make sure your valve train is up for the abuse though.
I went all out with strong pushrods, comp R's, crazy springs, titanium retainers, and good valves...
Old Jun 12, 2003 | 10:55 PM
WS6T3RROR's Avatar
i'd recommend the one thats in the middle lift wise. and the only reason is that it'll take heavy *** springs and comp r's to run the high lift one. the main diff here will be that as lift increases for a given duration the "area under the curve" will increase and give you more power with the same idle characteristics and drivability. since it wont be an all out racer and you probably wont gain a worth while for cost amount of power from the really high lift version and it'll kill valve springs just go with the midle one that seems to be where peoples ported stockers are peaking around anyhow. but if you've got the cash the 605/622 will make the most power provided the heads are still flowing up there.
Old Jun 13, 2003 | 12:28 AM
HtownZ's Avatar
make sure you get some bad *** springs.... careful when going with 111lsa that cmotorsports offers
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
ChrisFrez
Feb 1, 2015 08:26 AM
kandied91z
Jan 23, 2015 11:14 AM
1775.Z28
Jan 11, 2015 10:51 AM
