XE 224/230 and CMotorsports Stage II heads ... dyno results
366.8 rwhp
351.5 rwtq
The dyno sheet
My setup, in a nutshell:
Combination Motorsports Stage II heads
Comp XE 224/230 cam (.536"/.544") 112 LSA
Hooker LT's, Mufflex Y, Hooker catback
GMPP CAI, trickflow elbow, 52mm TB
T56, Stock 10-bolt with 3.73's
Torque was a couple ft-lbs lower than I expected but other than that I'm pretty satisfied
351.5 rwtq
The dyno sheet
Good numbers. I have the same cam but on a 114LSA and did 362hp with Lloyd's big valve heads.
You might want to check your injector pulsewidth though, unless you've jacked up the pressure. I was running stock fuel system with SVO 24 lb injectors and hitting like 99% duty cycle at 6000 rpms. I upgraded to 30's and I have plenty of injector left to grow into
Originally posted by trax
Fuel system is stock from pump to injectors.
new 30lb FMS injectors are only $199, why not get a set?
You should check the duty cycle of your injectors to make sure they aren't holding you back. I don't even know if mine are.
