WTF is up with this??
Old Jul 28, 2003 | 08:05 PM
94REDSTALLIONZ's Avatar
Ok..my friend ahs a 95 z28 with all the bolt-on's...so we decided the next thing on the list would be a converter..so we slid in a coan 3000 stall...now the car is slow as dog ball's....1st gear is awesome..but 2nd,3rd,and 4th are just dog's...and the check engine light comes on about halfway through the gear and it just bog's down REALLY bad like it's pulling timing or something??..also it shift's at like 4100 rpm..what the hell could this be?..i tried hooking up my scanner..but since it's OBD-1 mine wont work..but it has the OBD-2 ALDL connector..so i guess we are screwed on that lol...could this be tourqe managment?any help would be greatly apreaciated..oh and the ABS light comes on and stays on as well..dont know if that is a related problem though..Later,
Carter
Old Jul 28, 2003 | 08:43 PM
Geezer powered's Avatar
When you guys put the converter in did you make sure it clicked all the way in.(I think 3 clicks)Its alittle tricky.95 has obd2 connector but its obd1.You have the right amount of fluid in I assume.
Old Jul 28, 2003 | 08:46 PM
Yeah bro 3 click's of course...yep full fluid..dont know what the hell else to do?
Old Jul 28, 2003 | 09:37 PM
could be a bad converter
Old Jul 28, 2003 | 09:52 PM
Kwiksilverz28's Avatar
You gotta pull the codes. Find a firend at a dealer with the Tech 2 machine or whatever they are called...
The ASR isn't holding it back, is it? I don't know a lot about that system, but maybe it is retarding everything...
Old Jul 29, 2003 | 12:10 AM
AL SS590 M6's Avatar
Moderator
Moving to LT1 tech where they know all about the "high stall no shift"
surreybrad
Jul 29, 2015 02:55 PM
housh
Sep 20, 2002 06:40 PM
jthomas
Sep 6, 2002 03:18 PM
MadKilla
Jul 22, 2002 06:42 PM
BadAssed93Z
Jul 6, 2002 07:13 PM
