WTF!! o2 sims problem
i was getting a code for low activity, bank one sensor 2. so today i finialy got around to swappin out the drivers side sim for the passenger side sim. went to clear the code and i had 2 codes, no activity for both. cleared them and they came back on with 8 miles or so. are they dead? any ideas?
Re: WTF!! o2 sims problem
I think when you get a code that says no activity that means you have bad o2 sensors. I had the same problem until i bought some new o2 sensors and all the codes went away.
Try cleaning contacts, they may be corroded. Are all fuses ok? No burn wires from sims to PCM? Check PCM harness. You can use a PCM pinout and check voltage on corresponding pins, but as it quickly changes it will only give you idea of good connection. Thanks to Shoebox, you can find it here: http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
Magenta_Hearts
Mar 25, 2015 10:24 AM
