WTF!! o2 sims problem
Old May 12, 2005 | 03:56 PM
steves97z28's Avatar
i was getting a code for low activity, bank one sensor 2. so today i finialy got around to swappin out the drivers side sim for the passenger side sim. went to clear the code and i had 2 codes, no activity for both. cleared them and they came back on with 8 miles or so. are they dead? any ideas?
Old May 12, 2005 | 04:25 PM
Re: WTF!! o2 sims problem
whats the red light for on the box part for?
Old May 12, 2005 | 05:56 PM
LT1 POWR's Avatar
I think when you get a code that says no activity that means you have bad o2 sensors. I had the same problem until i bought some new o2 sensors and all the codes went away.
Old May 12, 2005 | 06:29 PM
so i should just buy new sims then, great another 90 out the window
Old May 12, 2005 | 08:54 PM
anyone know what the light is for? when i turned the car on to acc. they were both blinking red
Old May 13, 2005 | 11:43 AM
i called casper electronics, and the said if the red light is blinking the are both workin. what else could it be?this is never ending with this damn car
Old May 13, 2005 | 12:44 PM
1st 4th gen's Avatar
I am having the same problem with the sims on my 96 gmc truck. I have'nt had time to switch them but I lost side two bank two. Let me know what you find out.
Old May 13, 2005 | 12:48 PM
valter's Avatar
Try cleaning contacts, they may be corroded. Are all fuses ok? No burn wires from sims to PCM? Check PCM harness. You can use a PCM pinout and check voltage on corresponding pins, but as it quickly changes it will only give you idea of good connection. Thanks to Shoebox, you can find it here: http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
Old May 13, 2005 | 02:39 PM
LT1 POWR's Avatar
Like i said before its probably the SENSORS NOT THE SIMS.
timmy39120
May 2, 2015 05:12 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Cam's maro
Mar 24, 2015 08:09 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
timmat1
Jun 29, 2003 09:29 AM
