WTF!!! Fel-Pro oil pan gasket Is retarded and im pissed off *PICS*
Old Aug 6, 2003 | 01:21 PM
Acct 23749's Avatar
Im building a motor, and trying to not only make it run good and fast, but also be clean and look good. No oil leaks and lots of powder coating
Well i went to put on the oil pan gasket today. i put a lil RTV along the sides and a good amount on the arches on the front and back
Set the gasket on the and evenly and slowly torque them all down to spec.
I stand back to look at my work and WTF:
http://images.cardomain.com/member_i...3_136_full.jpg
http://images.cardomain.com/member_i...3_134_full.jpg
and
http://images.cardomain.com/member_i...3_135_full.jpg
The front of the pan gasket just popped out. So i took it off added a lil RTV again and put it back on..Same thing!!
Tried this about 3 more time with brother trying to hold it, a string around it still keeps popping back.
Now i got RTV everywhere, its dried too, and im sure it will leak now even if i get it right
What should i do??? anyone else have this problem???
so pissed off
Old Aug 6, 2003 | 02:43 PM
Transamdriver's Avatar
I went through that when I did my cam, The damn gasket kept bulging towards the outside. My timing cover was off so I hooked it on the lip of the oil pan gasket, then slid the timing cover onto the dowels. The gasket was buldging at this point and I pushed it in the best I could with my finger then tigtened up the oil pan and had to push hard with my fingers to get it to pop into place. It probably took me near 2hrs to get it to sit right.
And I also had Super Copper EVERYWHERE, including all on my hands. If it leaks, its just gonna leak cause Im not fixing it again until it really gets on my nerves.
Old Aug 6, 2003 | 02:50 PM
xchief1320's Avatar
If your trying to get it to stay use some 3M weatherstrip adhesive to hold the gasket in place,wait till it dries "which only takes 10-15 minutes or so"then use a LITTLE bit of RTV in the corners..no need to use it on the whole gasket..It just causes the gasket to slide around till it dries..
Steve
Old Aug 6, 2003 | 03:02 PM
I burn rice too's Avatar
If you're really having trouble try the O.E. gasket. Funny, my Fel-Pro pan gasket didn't look like that one. Maybe there are two different ones. Where did you get it? Because I did mine twice and got it from two different sources, Orielly and Summit. Maybe there is a better one than the one you got, because I never had problems with any of the two. Even the one I did under the car!
Old Aug 6, 2003 | 03:16 PM
Acct 23749's Avatar
I have the Fel-pro 64102 from auto zone (also has OS34500 on it)
I really afraid that if i go out and buy another $40 gasket is just gunna do the same
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
