Wtf!!!???!?!?!?!
Old May 16, 2005 | 04:23 PM
LT1grunt's Avatar
Wtf!!!???!?!?!?!
Had a puffing sound. Sounded like it was misfiring. Came AFTER I installed an DS to AC converter.
I changed the plugs and opti.
Still the same.
WHAT IS WRONG??????????
Car: -95 z28
Old May 17, 2005 | 11:42 AM
BLinindoll's Avatar
Re: Wtf!!!???!?!?!?!
Need to be more specific then, "had a puffing sound."
Old May 17, 2005 | 01:34 PM
LT1grunt's Avatar
Oh, it sounds like it is misfiring. Gets worse as it gets warmer. I have just changed the opti and plugs. NOT the wires, so I`ll get those next. One guy on Fuelslut thinks it might be the EGR valve.....
Old May 17, 2005 | 02:46 PM
Heatmaker's Avatar
Advanced Member
I got that sound when My Optical spark wasn't installed on the dowel pin correctly.
Old May 17, 2005 | 05:29 PM
LT1grunt's Avatar
well i used a company called extreme engineering and they had done this more than once so i dont think thats it.
Old May 17, 2005 | 08:47 PM
Heatmaker's Avatar
Advanced Member
To be honest with you only thing left to do is back track. Recheck your work...make sure the plugs are in tight and the wires are routed correctly... if they are then check the opti again. If those are the only items you touched than those would be the first places to look. I wouldn't bother with EGR and unrealted criteria till I was double sure everything is correct.
Old May 17, 2005 | 10:47 PM
LT1grunt's Avatar
Yea? The thing is the misfiring occured after an electrical hook up...
surreybrad
Jul 29, 2015 02:55 PM
housh
Sep 20, 2002 06:40 PM
jthomas
Sep 6, 2002 03:18 PM
MadKilla
Jul 22, 2002 06:42 PM
BadAssed93Z
Jul 6, 2002 07:13 PM
