Would you use head studs or bolts in this application?
Old Jun 21, 2003 | 11:37 PM
thewinner's Avatar
Im building a 383 with a good amount of nitrous. 200-225 shot.
Ive got a set of arp head bolts i used for about 200 miles till my goddamn head gasket leaked and destroyed my ****ing motor
Should I buy studs or reuse these bolts?
Old Jun 21, 2003 | 11:44 PM
Timberwolf's Avatar
I would go head studs... thats a lot of juice
Old Jun 21, 2003 | 11:46 PM
Mindgame's Avatar
I'd never use bolts on a performance build. Go with studs.
-Mindgame
Old Jun 21, 2003 | 11:53 PM
thewinner's Avatar
sick car mindgame.
What cam would you guys go with on a mostly n/a application, but running the nitrous ocassionally later on? I would probably only run the huge shots every once in awhile. Probably be doing a 150 shot or so for street racing.
right now i have a 230/236/112 .544/.555
heads flow
.100 64.2 47.8
.200 132.8 92.3
.300 188.6 134.5
.400 237.7 160.0
.500 267.1 179.1
.550 277.8 186.9
.600 279.0 191.7
springs bind at .600 lift.
thanks guys. please stick to off the shelf lobes if possible as i cant afford a custom, and i need it asap. i was thinking a 230/242/? .544/.578
What LSA should I go for to get a nice lope but not lose too much precious n2o?
Old Jun 22, 2003 | 01:07 AM
Mindgame's Avatar
Follow this link, http://www.cmotorsports.com/lt1customcamshafts.htm
Comp Cams 230XH Camshaft, 230/242 duration @ .050", .510"/.540" lift with 1.5 rockers, .544"/.576" lift with 1.5 rockers. Aggressive blower/nitrous cam for high horsepower apps
That should actually read .544"/.576" lift with 1.6 rockers.
That cam is also ground on a 114* lsa. That's the one I'd use for a nitrous motor.
-Mindgame
Old Jun 22, 2003 | 01:21 AM
thewinner's Avatar
thats the exact cam i was talking about couldnt remember the exhaust lift though DOH
114 lsa still lope good? cause i want a sick idle
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
CARiD
Jan 27, 2015 06:27 AM
Catmaigne
Dec 25, 2014 12:16 PM
