I removed my screen in my stock MAF...is that ok?
Old Jun 20, 2003 | 02:47 PM
MetallicTrans96's Avatar
I drilled some holes in my airbox and i removed the screen from my MAF.I was wondering if it will hurt anything....have any of you guys done this??
Old Jun 20, 2003 | 02:51 PM
revtime's Avatar
I don,t know about the drillin holes but the descreened MAF yes, I think most of us have done that.
Next you need to remove your AC.
What?...you mean everyone has not done that?
Old Jun 20, 2003 | 02:52 PM
JeffK95Z's Avatar
Lots of people have, lots of people wish they didn't...
do a search on !MAF and you'll find TONS of discussions on it...
Some have no problems, others do...
all in all, its a useless mod, and if possible, you might as well put it back in... it smooths out the airflow and allows the sensors to get a better reading...
IT IS NOT A RESTRICTION
jeff
Old Jun 20, 2003 | 02:56 PM
HungryT/A's Avatar
Altough some of us have done that, it is not recommended. It can throw up the MAF signals. Sympthomes would be rough part throttle operation, slight surging, etc.
I have done that and have regretted it..
Old Jun 20, 2003 | 03:33 PM
daveg96V6's Avatar
I descreened my mass airflow sensor and had no problems, but just to be sure I replaced it with a Granatelli one and have had no problems.
Old Jun 20, 2003 | 03:53 PM
Birdman7389's Avatar
I took mine out too, car started stubling a bit, promptly put it back in....pretty worthless
Old Jun 20, 2003 | 04:20 PM
BUBBA's Avatar
I bought a used one and descreened, ported and polished it. Then I sold it and reinstalled my stock MAF after Ed Wright suggested I do it when he programmed my PCM.
Besides, if you happen to have some foreign object hit those sensor wires or happen to make it to the intake, you WILL regret it. JMHO
Old Jun 20, 2003 | 05:12 PM
anaik's Avatar
Here is a good discussion on the MAF screen. It seems Brent had the MAF flowed with and without screen and found the screen to be a restriction. Also like said many times, it works for some and not for others. It works for me.
http://web.camaross.com/forums/showt...ght=maf+screen
Old Jun 20, 2003 | 08:41 PM
revtime's Avatar
I threw mine out years ago and never missed it.
My car ran 13.6 at 102 with few mods.
I never even thought about it again till you guys bring it up.
Maybe my car would of went even faster with it in. I don,t believe that though.
Old Jun 20, 2003 | 08:51 PM
DiabloZ's Avatar
Oh man.. do a search there are pages and pages of people arguing back and forth.. it comes out to about 50/50 one side or the other.. i got rid of mine years ago.
i is pretty much a personal chioce do it and see how the car reacts.. some are O.K. ,some have problems.
Old Jun 20, 2003 | 10:05 PM
stereomandan's Avatar
My instructions for the K&N cold air intake said to remove it. I removed it, and didn't notice any problems. Maybe it was o.k. because of the K&N CAI.
Dan
Old Jun 21, 2003 | 04:42 AM
SilvercamZ28's Avatar
I removed mine many moons ago and have never had a problem since... *knock on wood* ... what usually happens with people who perform this mod go al the way like I did (remove all of the interior of it port and polished) the some how mess up the TINY wires that are part of the sensor.. and that is why most of them have problems... I was careful and took my time and mine came out just fine.. and I also noticed a pretty sizeable gain in my air flow!
Old Jun 21, 2003 | 06:13 PM
JeffK95Z's Avatar
How did you notice a sizeable gain in air flow?
Old Jun 21, 2003 | 06:27 PM
InjectedSS's Avatar
Re: I removed my screen in my stock MAF...is that ok?
sweet bro you drilled holes in your airbox you should get one of those tornados while your at it! maybe you could put some prolong in you motor that way when you suck a rock or dirt into your engine everything will be ok
Old Jun 22, 2003 | 12:20 AM
Actually with the mods I already had done... I noticed a pick up in my upper RPM range... knock it all you want.. but I am one of the few that it worked for!
